Question about Palm Tungsten E2 (Multilingual) Handheld
More applications than I should have
I used to own a Sony Clie. I've upgraded to the Tungsten E2, but when I hotsynced for the first time, some of my old clie apps ended up on my new Palm (thought I'd removed all of them from my computer). How do I delete these apps from the handheld?
  • 23 Answers
On your main screen touch the menu icon (bottom right in your graffiti box). This will open your drop down menu. Touch "delete" and a list of programs, etc will appear. Select one at a time and then press delete.
Hope this helps
Posted on Aug 04, 2008
Hello, it seems my palm Tungsten E2 is not compatible with Windows 7 (hotsync). Anything I can do or is there another PDA that will work? Thanks, I do need the PDA.
you need to uninstall the version of palm desktop that you alredy have and install the 4.14 palm desktop, with the hotsync manager that 4.14 includes you should have no more problems
Feb 01, 2010 | Palm Tungsten E2 Handheld
How to move data from Thngsten E2 to new computer?
if you use the latest Hotsync Manager - version 7.0.2, you should click Setting, then Applications.
You will get a list of applications that you can synchronise with your PC. Place a check mark beside those you want/need. Make sure to click the Configure button ( bottom right hand side) and select the Handheld overwrites Desktop for each application. Click on the Set as default...
This should ensure that the data is copied from the handhelp to the PC, and nothing gets overwritten on the handheld.
May 27, 2009 | Palm Tungsten E2 Handheld
Tungsten V
Re-arrange port configuration, install latest version of palm desktop. Right click on palmsync icon on system tray and check "Local Serial" . You may also use IrDa as alternate sync method
Apr 04, 2009 | Palm Tungsten E2 Handheld
During hotsync, data wont transfer from Computer to palm
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Mar 31, 2009 | Palm Tungsten E2 Handheld
Palm tungsten
you may want to run through a few troubleshooting tricks
first try pulling out any extra USB type items that you remove and replace frequently (like a flash drive) and restart your computer after its done booting up you can try hotsyncing again. Make sure what you wanted to put on your PDA is still in the Hotsync manager box.
A PDA not wanting to hotsync is a very general statement. It is an indicator for many different problems.
-You may need a new hotsync cable
-try a different usb port on your computer
-you could open the PDA up and check if all the contacts are clean and connected (Warranty void alert)
-Try re-installing the PAlm desktop software
-If nothing else works put whatever application you're trying to hotsync onto a SD card and copy it from the card and onto the PDA
Tungsten Es are excellent PDAs and it doesn't have too many problems besides being too "basic". A problem like not hot syncing probably isn't an indicator of something really bad unless you've dropped it too many times.
If all else fails you may need to pick up a different PDA
Jun 19, 2008 | Palm Tungsten E2 Handheld
Synchronizing my Tungsten E2 with the computer.
If you have not already done so, install the Palm Desktop software from your CD. (If you do not have a CD, you can download the Desktop software from palmone.com.)
Connect the USB cable to your PC and to your E2. (If you do not have a cable, you can probably find one on eBay.)
If the cable has a button, push it. If it does not, open the applications menu (the "House" button to the left of the graffiti area) and look for the app called "HotSync". Run the HotSync app, make sure that the Local/Modem choice (above the central hotsync icon) is on "Local" and the combo box below the icon says "Cradle/Cable". The tap the icon. If this is your first sync, you may have to answer a popup on your computer before it will proceed.
Feb 23, 2008 | Palm Tungsten E2 Handheld
Sony Clie PEG-T615C Hotsync doesn't work with my Windows Vista Home Edition
I must maintain my older XP system just to maintain my pda. Awkward, for sure. I have not contacted Sony yet.
I once discarded a very nice, functioning rinter by Canon because there was no driver for XP.
Ouch!
Dec 12, 2007 | Sony CLIE PEG-T615C Handheld
Unable to hotsync with my computer
Also, if you have a new Tungsten E2 and there is no important data, I would hard reset it and then when you sync it, select the old profile of the previous Palm to see if that works.
The new Palm you have, is it a Tungsten E2 as well?
The profiles don't always carry over between different models.
Sep 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
How to HotSync Clie' and Palm Zire
install it on another computer buy her a computer
Sep 19, 2005 | Sony CLIE PEG-TG50 Handheld
Palm Tungsten E2 (Multilingual) Handheld Logo
46 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
