Question about Insignia 50 in. Flat-Panel Plasma HDTV
Insignia flat panel tv
I have a 50 inch Insignia plasma tv. I want to select the aspect ratio labeled "horizon". (Pushes out the sides to fill the screen) This option is grayed out on my tv. Is there a setting I can change to allow this?
Thanks!
  • Mercurge May 22, 2008
    Update - It will go into Horizon mode while playing a dvd - just not with the TV
    Genius:
  • Insignia Master
  • 1,689 Answers
I don't exactly know your model. I can give you a generic type answer.
I can tell you that when you select to have the full screen, it may not work in the mode for the tuner. The reason is that the programs coming in from your tuner are actualy 4:3. When asking for a full screen you are asking for a 16:9 type format. This would stretch a 4:3 picture.
Have you tried contacting the manufacture, or if you know their local factory support place for your area?
Jerry G.
Posted on May 22, 2008
Aspect ratio is incorrect, not proper screen size
Check its user manual for details about adjusting the aspect ratio or contact the dealer.
Apr 17, 2013 | Insignia Televison & Video
Change screen from wide to regular our cable guy put it on wide my control will no longer change it
Vizio has a set of buttons on the left side where you can access your settings and change the aspect ratio of your TV. Though why you want it changed is beyond me. Wide screen is for 16:9 aspect ratios. At 4:3 (Standard) you won't be using your full TV picture.
May 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a 50" Plasma
Hi, the aspect ratio is set incorrectly for the source material or the screen is simply set to 4:3 aspect (old TV size) manually. There will be a menu function or an aspect button on the remote for doing this. Set it to auto which is usually good enough for most viewing though the ratio may change during adverts and back again for the film on tv watching. This can be annoying so when on tv mode observe the ratio set when the film is on and manually set this ratio, usually 16:9. The display will normally tell you the ratio setting at the point of change so you can do this. I hope this helps.
Steve at Olive Country Computers in Spain
Feb 19, 2011 | LG 50PX5D 50 in. Plasma HDTV
Tv will not move out of zoom mode
Hello; All HDTV's have some kind of menu item only on the original remote control, which could be labeled as aspect ratio or screen size ETC. Read your owner's manual or download one if needed. John
Feb 13, 2011 | Vizio VP50 10A 50 in. Plasma TV
Just purchased a 32 inch insignia flat screen model # NS-32L430A11, How do I make the picture the full 32 inc instead of the small screen in a box?
Look for 'ASPECT', 'MODE', 'VIDEO', or 'DISPLAY' on the remote button to change the aspect ratio.
One thing to remember is that if the video was made for 4:3 old TV format, when you expand it to fill 16:9 screen, people will loof short and fat.
Dec 04, 2010 | Insignia IS-LCDTV32 32 in. Television
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
On my Insignia LCDTV26 I have almost 3" of black screen on the right and left side of the picture.
This is normal if you're watching a 4:3 (full screen) broadcast or movie on your widescreen (16:9) TV. You can adjust the screen aspect by going into the Settings Main Menu and selecting System, then Aspect Ratio. I hope this helps!
Jul 22, 2009 | Insignia LCDTV26 26 in. Television
50 inch plasma ge tv. picture is to big
You will have to go to the setup on the LG50P.... and get to the picture resolution, For example your monitor settings should have the ablitiy to set up the 4:1 or 16:9 aspect ratio. The best is to set this at automatic ... usually the case on a 1080i or 1080p
Jun 19, 2009 | LG 50PG20 50 in. Plasma HDTV
How do I adjust the picture to fill the screen
i was having problems in the tv menu getting full screen. no matter what i did there was two black bars on each side of the screen. i have att u verse so i went into the cable menu to options. In the options tab i went down to system options then to aspect ratio. in this screen you get a few options like 4:3 standard definition and 1080i on high def screen. I chose 1080i high def and then played with the zoom function on my remote and the problem was solved. hope this helps
Nov 19, 2008 | Insignia LCDTV26 26 in. Television
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Insignia 50 in. Flat-Panel Plasma HDTV Logo
261 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
