Question about Compaq Presario R3000 Notebook
Battery won't charge
I have a Compaq R3000 that is typically plugged in to the AC adapter, but occasionally I run it off the battery. A couple of weeks ago when I unplugged the AC adapter the computer immediately died, as if the battery had no charge. I ordered a replacement battery, but this one behaves the same. When I check the power monitor the battery appears to be stuck at 0% or 1%, even when it has charged over night. The charge light is on when the computer is plugged in, but it appears to go out after 30 minutes or so. The computer runs fine on AC power, but dies immediately if unplugged. Any thoughts?
  • 3,940 Answers
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
Posted on May 22, 2008
I have a presario r3000, the battery is not chargi can run laptop with ac dapter
u can run u laptop without battery but u need to provied Ac adapter.
Feb 05, 2011 | Compaq Computers & Internet
Compaq R3000 new battery but does not work
Make sure you have the right AC Adapter hooked up to charge the battery with.
If you do then its a problem with the motherboard. If your using an offbrand ac adapter then that could be the culprit.
Dec 01, 2009 | Compaq Presario R3000 Notebook
Battery will not charge with AC adapter. battery will accept a charge as I tried the battery in a R3000 . Is there A common problem with the circuit board perhaps?
I would get the power board checked/replaced if its seperate from the motherboard. all laptops sometimes have this problem.
Aug 08, 2009 | HP Compaq Presario R4000 Notebook
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
My Compaq R3000 does not charge up
The problem might be the battery itself. Four years is a long time for rechargeables. Also, check if the error ocurs when the battery is not in the slot.
Oct 27, 2008 | Compaq Presario R3000 Notebook
COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
Aug 27, 2008 | Compaq Presario R3000 Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Itermttit ac and battery power on laptop compaq presario r3000. ac sees to work fine and then goes to battery (battery discharges in less than 30 miutes) - mp
your are probably experiencing a short in your ac cable, the next time it happens wiggle the cable, if the ac pops up in the task bar stop using the charger and buy a replacement.
PS check the slot where the adapter plugs in the back of the laptop to see if its loose, if it is take to the repair shop.
compaq are known for tis problem.
May 26, 2008 | Compaq Computers & Internet
Compaq Presario R3000 Notebook Logo
277 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
