Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" magnavox tv
I have a 60" magnavox tv model 9p6040c102 the green powerlight comes on but no picture or sound
  • Anonymous Aug 28, 2008
    SAME THING WITH MY 55IN. LIGHT IS GREEN ON TV BUT NO SOUND NO PICTURE???
  • luis_jaime60 Aug 31, 2008
    no trabaja las convergencias y reconoce el control remoto tv philips magnavox modelo 9p6040c102 chassis ptv843 de 60 pulgadas
  • Philips Master
  • 3,459 Answers
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
Posted on Jun 21, 2008
  • Edward
    Edward Jun 21, 2008
    I had the same exact same problem. You can get a repair kit from this site.http:///www.magnavoxhelp.com
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Philips Magnavox 9P5040 C104. Green power light- no sound/ no picture, fuse good.
Hey my tv is doing the same thing. The green power light with no sound and no picture and the fuse is good. I was wondering if you fixed the problem and if you could tell me how to fix mine.
Nov 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
61 inch phillips magnavox tv with no picture or sound
Its a common problem with this model.
Goto www.TvRepairKits.com and get their kit + instructions for the shrinking video problem.
Jun 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Screen is getting darker
The most likely cause is the blue and green tubes need to have the cooling fluid changed. After many years the blue and green get clouded with algae. The red tube won't have the problem due to the red spectrum kills the algae before it has time to grow.
The way to replace the fluid for is to completely remove each CRT from the set, remove the drain plug, drain the fluid out the tube, disassemble the lens, give it a good cleaning; then reassemble; add fluid; and reinstall in set. If you check with the site www.TvRepairKits.com they are working on a kit that includes the fluid and photo instruction guide.
Dec 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
283 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
