Question about Kenmore 30169 Electric Single Oven
F2 Error Kenmore Built-in Oven
Model No. C970-47821-1
Serial No. NF22803206
If it's beeping and saying F2, all you have to do is pull out the latch once, then put it back. This worked for me.
Posted on Feb 03, 2009
Oven heats & then beeps code F2EO then stops heating
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Jun 19, 2013 | Maytag 30" Built-In Single Electric Wall...
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
F2 code on a oven mod#911-41069690
go to repairclinic.com click on repair help, then error codes... scroll to kenmore (it will give you a list by the first 3 digits of model number, who really made the machine.. (kenmore doesn't make anything) then go to appropriate brand and find error codes.
Feb 25, 2009 | Kenmore Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Error code f2 after replacing sensor.
If the sensor utilizes a plug, it is not uncommon for the plug connection to become intermittent. Cut the plug off the sensor and the wire harness. Directly 'hard wire' the sensor wires to the harness wires using CERAMIC wire nuts.. (no polarity here, sensor is a resistive element) regular plastic wire nuts will melt. If problem persists thereafter, the electronic control may have to be replaced.
Jun 08, 2008 | Kenmore 47834 / 47832 / 47839 Electric...
Kenmore, f2
I can help but I need a model number
Kenmore are made by many different manufacturers of their appliances..
F2 error is most likely a oven sensor problem . your over sensor has to low or high Ohms or you Electromic oven control thinks it has to high of an Ohm reading. replace oven sensor and or control
let me know if this helps
Jun 06, 2008 | Ovens
Oven
F2 is aproblem with the oven sensor part number WB21X5301
Mar 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30169 Electric Single Oven Logo
816 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
