Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
NO SIGNAL issue
I have Dish network. when I first turn the set on I get a "no signal" showing but have audio. After leaving it for a few minutes it generally comes on but then will go off when it so chooses. It comes and goes from picture to no signal with no particular pattern. Dish says it is the TV. The TV has not been moved and the cables have not been bothered with. This has been going on for over a week. What is the problem?
  • olijam365 Aug 07, 2008
    Please help me, my television is Samsung HRL4667WAX/AXXA, at the moment there is no signal or weak signal appears on the screen. Please let me know what to do, does it worth fixing. Thanks
NO Signal Issue - Plasma
Posted on Jun 03, 2008
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
When the receiver powers up just the fan seems to go on. Resetting by holding the i/o will turn the yellow light off but doesn't turn the fan off and comes back on after you release the i/o...
Hello Joe, my name is Becki, with DISH Network. You will want to make sure that the receiver is in a well ventilated area, and that there is nothing heavy sitting directly on it. The receiver's fan can start running constatntly if the unit starts to overheat. You may also want to try putting the receiver out on the floor for a few hours to cool down. You can also try to unplug the receiver from the power source for 10 seconds, that can be a more thourough reset than holding the power button down. The fan will run while starting the receiver up, for about 5 minutes, then it should stop running loudly. If you continue to have problems, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP 612
My dtv pal dvr is a few months old and is unusable. It freezes up sometimes for hours i cant even turn it off. The content comes off an antenna that gets a strong signal but it skips like it is getting bad...
Hello! Dan Busa with DISH Network customer service. This may be a signal reception problem you can try checking cabling and connections coming from your antennae.
Dec 30, 2010 | DISH Network DTVPal DVR by
Screen "blinks" black every few minutes - Dish Network
Hi, Mary with Dish Network Customer Service. When the picture alternately goes from normal to a black screen, it is an indication of an intermitten signal issue. You can attempt to reset the receiver box by unplugging it from the power for 10 seconds and letting it reboot. Hopefully this will resolve your issue.
Jul 31, 2010 | DISH Network 322 DTV Receiver
We have an old dish network dish and LNB with a new dishnetwork receiver. When we can get the signal up to 5, the screen goes blank and we cannot lock the signal in. Diagnostics state there is no...
Hi mfpayton with the install of the brand new receiver wealways want to make sure all connections are tight. And after all connectionsare hand tight we will need to run the Check Switch Test. It will provide thestrongest signal to your home and you will see the signal move up into the 65percent range. If after the Check Switch Test it still is a low signal we mayneed to check the connections from the Dish and LNB that is an issue we wouldneed to come out on. I will leave the link to show you how to do the CST.http://www.dishnetwork.com/SupportSection/complete-sig-loss
Mike Houston of DISH Network Executive Office
May 02, 2010 | DISH Network 322 DTV Receiver
We have a black screen with no audio. We are able to pull up the guide, but we can't watch tv or anything recorded on the DVR. How do we fix it?
No fatal error, try this. If you would, please unplug the receiver from the power outlet for about 2 minutes. After 2 minutes, plug it back in and let me know when it comes on (it will do this by itself). Once it does, it should be showing Message 015, “Acquiring Satellite Signal”.
http://tech.dishnetwork.com/departmental_content/TechPortal/index.shtml
Oct 10, 2009 | DISH Network 322 DTV Receiver
Problem with recording playback
i would suggest unplugging the receiver from the power outlet for about 10 seconds and then plugging it back in, do not turn receiver back on, it should come up on its own after a few minutes, if it doesnt wait another minute and then press power, it will reacquire signal and then you can try again. is this issue only effecting tv1???
Jul 15, 2008 | DISH Network DVR-625 DTV Receiver /...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Video works when playing DVD, but not with Dish signal.
I have the same problem.I turned it off for 5 minutes then turned it on and off a few times.
And I hit it to, not recomended
Jan 18, 2008 | Sony KV-27S42 27" TV
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Henry  Thomas
Henry Thomas
