Question about Ahead Software Nero 6 Ultra Edition (2434nl20) for PC
Nero 8. Neresize.ax file crashes my XP pro PC. Had to rename file to get my PC to work now Nero Home does not work any ideas ran Nero Clean before installing and uninstalled previous version!
NERO 83.6.0 PLYS SERIYAL NUMER
Posted on Nov 05, 2008
When i turn on my pc i get the message "windows host process (rundll32) has stopped working.
Try a system restore if you can to before this occured
OTHERWISE
Please follow these instructions to check which software is causing this issue:
1. Click on Pearl (Start Button), in the serach box type:
msconfig
and hit the enter key on the keyboard. It should open the System Configuration Utility window.
2. Click on Services over the top and then at the bottom right corner, put a check in the "Hide all Microsoft services" checkbox.
3. Click on "Disable All" button.
4. Click on "Startup" tab, and then click on "Disable All" button again.
5. Press OK button and then "Restart" button on the following window. Let the computer restart.
6. Once you're back on the desktop, you'd get a window for System Configuration Utility. Put a check in the box "Don't Show....." and then press OK button.
7. Now, once again check the issue. If the issue is resolved, open System Configuration Windows again and then enable all the services from Services tab and then check the issue after restarting the computer in the same way as mentioned above.
8. If issue is still resolved, enable half of the Startup items from Startup tab and then check issue.
9. If issue occurs again, it means, there's a culprit in the checked startup items. But if issue doesn't occur, then issue could be with rest of the Startup items. Now, uncheck the first half startup items (that were check before), and then check rest of the half items. Check the issue again.......
10. Now, if the issue occurs, then make a note of all the names of the startup items and then follow the same procedure, for them. Now, you need to be careful, as by design the System Configuration will sort all the enable startup items to the top. So, it means all the entries would be mixed on next reboot. From now on you need to make a note of all the entries that you're enabling or disabling........
Aug 22, 2009 | Microsoft Windows Vista Home Basic Edition...
Tip
Get crash ID's
To get your crash ID's go to about:crashes in your firefox location bar. Copy and paste ID into post, when support is needed.
If you are unable to do this...
In Linux:
  1. Open up home folder
  2. Click "View"
  3. Click "Show Hidden Files"
  4. Find the folder ".mozilla"
  5. Open the folder up
  6. Look for "Firefox" folder
  7. Open "Firefox" folder
  8. Open Crash Reports folder
  9. Right click on file
  10. Click "Rename"
  11. Copy entire name.
  12. Paste into post.
In Windows Vista
  1. Click "Start" (Windows Orb)
  2. In search box, enter %APPDATA%\Mozilla\Firefox\Crash Reports\
  3. Press enter
  4. Right click on file
  5. Click "Rename'
  6. Copy entire file name
  7. Enter in post
In Windows XP/2000
  1. Click "Start"
  2. Click "Run"
  3. Enter %APPDATA%\Mozilla\Firefox\Crash Reports in "Run" window
  4. Press enter
  5. Right click on file
  6. Click "Rename'
  7. Copy entire file name
  8. Enter in post
on Jun 20, 2009 | Mozilla Firefox
Tip
Fix for COM Surrogate Has Stopped Working Error in Vista
You get an error message that COM Surrogate has stopped working whenever you browse folders containing video or media files, This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible, like some versions of DivX or Nero.
There are a number of possible solutions to this problem, and the right solution depends greatly on what software is actually causing the problem. Some of the most well-known problem causing softwares are DivX and Nero, but there are others that cause the problem as well.
Possible Solutions
  • If you are using DivX, you should be upgraded to the very latest version (6.5+)
  • If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
  • If you’ve upgraded Nero and Divx and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
    This will break Nero Showtime, however.
  • You can disable Thumbnail previews, which should make the problem go away, but isn't the optimal solution.
  • The older ffdshow codec pack has been known to cause some problems. The ffdshow tryouts codec pack seems to work better. Might want to try using this one: http://ffdshow-tryout.sourceforge.net/
  • If you'd like to uninstall Nero entirely, there is a utility that they provide to help with complete uninstall that helps a lot in instances where you have a bad installation of an older version. http://www.nero.com/nero7/eng/FAQs_Nero7_NeroVision.html
  • Some users have recommended installing the Vista Codec Package in order to update all your codecs to the correct versions.
  • You can use the very useful MMCompView free utility from Nirsoft to disable any codecs on the system. This is very useful to help troubleshoot exactly which component is causing the problem.
  • There's another possible solution below of turning off DEP for dllhost, which might not work for everybody. You may have to add divx+nero executables to the DEP ignore list.
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate) can fix this problem for some people. This solution is detailed below.
Right click on Computer, and choose Properties
Submitted by Avishrant Gaur You get an error message that COM Surrogate has stopped working whenever you browse folders containing video or media files, This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible, like some versions of DivX or Nero.
Here's the error message:
Possible Solutions
Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe as shown
Click Open, and then OK.
Here's what you should see…
Now you can browse video folders without problems!
on May 30, 2008 | Microsoft Windows Vista Home Premium with...
Windows Explorer sends continuously error messages
Turning off thumbnails will probably stop you getting that error
DO:
Open Control Panel > Folder Options > Always show Icons, Never Thumbnails
However, this isn't actually fixing the problem.
Do you have Nero installed by any chance?
If so try:
Open Computer > System Drive > Program files > Common Files > Ahead > DSfilter.
Rename "NeroVideoProc.ax" to "1NeroVideoProc.ax"
Also rename "NeVideo.ax" to "1NeVideo.ax"
And then reboot.
Nov 11, 2008 | Computers & Internet
I cannot seem to burn dvds in nero to be read on xp home/xp pro
When you go to burn a cd/dvd there should be and option for you to tick that allows you to burn the cd/dvd for other computer etc... to use too, before you click on burn have a look around for the options on that page
Oct 23, 2008 | Computers & Internet
WINDOWS EXPLORER HAS STOP WORKING
Hey there
The problem could be because earlier version of nero You can solve your problem from doing the following:
If you’ve upgraded Nero and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
There's another possible solution below of turning off DEP for dllhost, which might not work your windows explorer
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate or windows explorer) can fix this problem. This solution is detailed below.
Enjoy working
Gimme your acknowledge by rating me
thanx
Romy
Oct 18, 2008 | Computers & Internet
Problem
Hey there
There's another possible solution below of turning off DEP for dllhost, which might not work your windows explorer.
Enjoy working
thanx
Romy
Aug 20, 2008 | AMD Chaintech ZNF3-250 Socket 754...
Windows explorer has stopped working
Hey there
thanx
Romy
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
Vista crashes while publishing movie in Windows Movie Maker/DVD Maker
i just found out the problem.
I have nero 7 installed on vista. To fix the vista movie maker crash when rendering, I just renamed this folder
Renamed DSFilter to something else. VMM no longer crashes and when I want to use Nero again, just rename DSFilter back to normal.
Jun 28, 2008 | Computers & Internet
Crashing!!!!!!!
First go to recovery console. try this command after the command prompt. CD system32\drivers\ Enter Last line should be: C:\windows\system32\drivers> then... Expand the file from the CD. expand d:\i386\ntfs.in_ or expand d:\i386\ntfs.sy_ if this doesnt work try to run CHKDSK /R. if you get any error while running checkdisk repair you will need a hard drive replacement.
Oct 03, 2007 | Dell Memory Board PE6450 (1409D) Expansion...
Ahead Software Nero 6 Ultra Edition (2434nl20) for PC Logo
96 people viewed this question
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
