Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi WS-48613 made in 2003
Won't turn off at times. Hit system reset and may come back on after green light stops blinking. When it does come on no buttons on remote or front of tv function right and the volume goes up and down by itself and usually stops at full volume. Cutting power for several hours and restarting does not help. Help!!! No dealers around Chattanooga, TN that I can find. Any suggestions? e-mail at jcs244@comcast.net Thanks.
  • Doonger Jun 05, 2008
    Similar problem, except mine won't turn ON at all. Light has been blinking for almost an hour now - it stopped a couple times, but just started blinking again when I tried to turn the TV on (and the TV did not come on). Tried hitting the system reset button, which stopped the blinking while I held the button down, but it just kept blinking again when I released it. Tried unplugging the TV, but it just blinked when I plugged it back in. Any ideas?
Have not solved it but wanted to reply. do not appreciate your original offer for informatiion and help when all it was an attempt to get one to sign up for and pay for your service. i will seek help from someplace that is not trying to scam me.
Posted on May 26, 2008
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
