Question about Acer Aspire 5100 Notebook
Streaky screen I bought my Acer laptop at the beginning of th semester. This morning when I left, my laptop worked fine. When I got home this evening after classes, it didn't work right. The screen appeared streaky. Across the top it read something like Windows Recovery Error, so I pressed and waited a moment. Like usual I typed in my password, even though I couldn't see the area. My wallpaper showed across the top .5" only and in this area only did my arrow show up. I turned the power of off/on and went through the same sequence. I had to go to the comp.commons on campus to even find the website. What should I do? I'm not even sure which Acer I have. I have the same issue on an Acer Aspire 9800. My streaks are definitely artifacts. The screen is not broken. They're vertical, uniform, in groups of four, and dark in color. The first thing that happens is that my windows toolbars and buttons change color when I roll over them. They don't return to their original state, but whatever is supposed to be gray turns red, and all other colors are off. Then I shut down and I see the Acer splash screen just fine. When Windows loads, the streaks are there. Then I get a BSOD referring nv4_mini.sys, which is an Nvidia driver. I reinstalled Windows (and all drivers), and it worked for a couple days. Then the red toolbars all of a sudden and the streaks came back following a reboot. I'd really appreciate a solution to this. Thank you.
    Sergeant:
  • 291 Answers
Try and replace the power supply, If u have an external (black box) type of power.If you can find someone with the exact external power supply or a universal. I Think the it is not being filtered properly.
you can download nvidia software drivers for free, then uninstrall what u have & reinstall with the downloaded drivers.
get back to me @ dmsr3@juno.com for instructions.
other then that u could have a bad video section. or one of the circuits on & around the screen could be going bad.
p.s. the reason I suspect the dc power is what u said " I reinstalled windows ( and all drivers), and it worked for a couple days"
Posted on May 21, 2008
  • 111 Answers
Try to download and run "memory test" from microsoft website. Also read the instructions on how to use it.
Most of the time the Memory is the culprit for this kind of problem.
Hope this helps.
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Should I bother trying to fix this laptop or is it time for new?
it would be cheaper to get a net book and an external hard drive you can get a good one for about 200$ and an external drive enclosure for like 20 and a used hard drive for like 30-40
Dec 17, 2009 | Acer Aspire 3000 Notebook
Acer factory backup does not start my computer
I have the exact same laptop as you. I've had this problem before. I bought the DVD's from Acer to reinstall everything and there are times when they don't work. I left it sit for a week and it stayed on the same screen. I would just keep trying, or order the DVD's from Acer. It will cost about $30 but might be your only chance.
I don't know if this is a flaw of this computer or not, but even with a different HDD in it it does the same.
Nov 28, 2009 | Acer Aspire 6930-6082 Notebook PC
Blank screen on my acer aspire 3680 laptop
Sounds like you have gotten stuck in presentation mode. Hold down the function Key (Fn) its blue, and then hit the (F5) key once. If the screen doesn't come back, press both again.
May 17, 2009 | Acer Aspire 3680-2022 PC Notebook
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Streaky screen
On the bottom of the laptop. You should find the serial number and model number.
It sounds like the LCD has some issues. I recently repaired a machine with a simular problem, but the screen was more "splashed" than streaked. By that i mean you could clearly see the screen was smashed.
Would you say your streaking is more like "Digital" streaking what we call "Artifacts" or its like a splash of water on it, where maybe its been smashed.
If its the other, try safe mode with VGA support. That should disable any other programs or settings causing the problem.
Oh! And when you first boot the machine, does the "ACER" logo look normal? How about the windows boot screens?
Oct 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5100 Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
