Question about Nokia 6165i Cellular Phone
Lost configuration a) I can figure down why after any complete charge lost (zero, zero dead!!) when I charge again I've lost all screen pictures an protectors. Is it normal? b) Is there any way for reaching the dictionary. I have lots of messy world I never introduced there!!. plus lots of other ones which I never use and I need room for the one I really use a lot.
  • Anonymous Feb 08, 2009
    can someone help me?my phone only comes up with a white screen and everything else works...it has fallen pnly once
My iPhone battery drains quickly
Hi, many things can contribute to battery drain, what model and IOS do you have?
Oct 31, 2013 | Cell Phones
My nokia 6220 wont start. When holding down the "on" button it just vibrate a little and the screen lights up a little bit, then it goes back to completely black again
The battery cell may be completely dead and you need to replace the battery. Because its going completely black again means its actually completely of. So try and change the battery, but make sure you charge it till its completely full before usage. Hope that puts a smile on your face.
Oct 13, 2009 | Nokia 6220 classic Smartphone
HTC S710 - Battery issue
Hi guys
if u buy new battery for around 35$... its creepy thing that it again sucks within
6 month
so follow these procedure that i really got good response
1)Buy the new battery from any other dealers (u can use Nokia (std) or LG, Micromax, Onida... etc)
having same specifications as 1050mAh Lion-POLYMER 3.7v and having equivalent Size that fit into the case.
2)Now open ur dead battery, remove the sticker slowly, u wil get the polythene bag carrying the charge sheets
3)Please note that dont not disturb this polythene bag... (cutting, drilling or pinning), else it starts burning.
4)U will see a circuit above the polyhthene bag having two poles (+ve n -ve) just cut the poles of bag from the circuit and keep the bag aside
5)Now do the same procedure with new batt and remove the polythene bag.. and soilder with
the dead battery circuit. (check the +ve n -ve by multimeter)
5)Re-assemble with insulation tape and recondition it perfectly.
now check poles bofore starting.
Note : i got good result from this and i m getting 18-19hrs standby and 11-15hrs usage. Do it on ur own risk...and i m not responsable for ny harm)
Jun 02, 2009 | HTC S710 Smartphone
Philips dvp 3020 dvd player
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 22, 2008 | Philips DVP-3005 DVD Player
Creative Zen Vision 30G not Turning On
Alright guys, I think I've figured it out.
I got mine working again, and it's been down with the same problem since the 29th.
So I tried to do the "Hold power for 30 seconds while plugged into your computer" thing. Didn't do anything, but thing is, I didn't unplug it from my computer afterwards, I just went to bed, and when I woke up, my creative was working again.
This, coupled with Oddu's solution have pretty much made me positive that for the problem we are having (only a blinking blue LED when connected to the PC or when you hold the power button) is just caused by an over-dead battery.
Plug your Creative Zen: Vision M into your USB 2.0 port, and just leave it overnight, mine was plugged in about 7 hours, I reccomend leaving it in at least that long, if not longer if it's still not working.
The situation that lead to mine becoming this way, was my Creative froze, and I didn't have a mechanicle pencil with me to hit the small reset button on the bottom so I just let it stay powered on until the battery died. I guess that kind of completly dead battery screws it over.
For prevention in the future, I reccomend not letting your creative get down to 0% battery. Keep it charged.
Jan 25, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Vplus hangs while charging
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
M515 green light on and dead screen
Hey, i had the same problem. My m515 stayed with the green light on for 3 days until the battery died out (and lost all my data). I keep the m515 off and without recharge for 2 more days. Then I recharge it in its craddle and it seems to be ok. Good luck
Sep 19, 2005 | Palm m515 Handheld
Battery charge
Put 2 batteries in flashlight and ran completely dead. Charged them in 1hr. 50min. Pulled plug per directions for first time charge and plugged back in. Light went out in about 10 - 15 min. Plugged in third time with same results. Is this normal. Haven't tried them in camera yet.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Open Questions:
Nokia 6165i Cellular Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
