Question about Maytag MER5775Q Electric Kitchen Range
Control buttons: The word Off comes up, oven's not working
Everytime I hit any button on the control pad, the word "OFF" lights up.
    Sergeant:
    Champion:
  • 338 Answers
Replace the control
Posted on Nov 25, 2008
Ho to set Clock on GE Mod JRS068 J1BB
On GE ovens there should be a CLOCK button to press first. Then if the control has number pads 1 to 0 you enter the correct time and press clock or start again to finish. If it has no 1 to 0 pads there should be 2 arrow type buttons with + on one and - on the other. Press clock and then use + to go up or - to go down. Holding either button in will make it change fast. When you get close to correct time hit button slowly to finish. Hit clock button when time is correct.
Mar 09, 2015 | GE Ovens
Micro wave oven light works as a work light but when you hit the button for the night light to come on it doesn't come on hit the button again and it's off
The problem is on the control panel, which can be repaired economically.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 17, 2013 | Microwave Ovens
After the oven is on for about 5 seconds it has a buzzing or humming sound
This seems to be a failure of the control panel pad or switch as it does not take the command.
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Jan 11, 2013 | Amana MVH230 Microwave Oven
I cannot get the light to turn off on my Hampton Bay fan. Everytime I turn the fan on the light also automatically turns on. The remote appears to be useless, everytime I hit the light/dimmer button...
Possible that the logic control within the fan unit is defective if is seems to switch on both. For a start you can try to clean the remote pads to confirm if the pads are accidentally contacting when pressed for one function. If dimmer works then the selection mode could be the culprit.
Jul 04, 2012 | Hampton Bay YG092-VPW 52'' Preston Vintage...
JJW8230DDB Jenn Air double oven. Black. Digital display. The only buttons working on the display are the Cancel buttons. Display still shows time, but I can not set the time (the clock button does not work...
When buttons are not working most of the time it is due to a short in the touch pad or the electronic control in a unit you would have to call for service if you did not know how to use a multimeter to perform ohms and continuity testing and measureing of both pieces. Usually though due to the button not working most of the time it is the touch pad though. If you have any further questions message me back Thanks again
Rick
Oct 16, 2011 | Jenn-Air JJW8230D Electric Double Oven
The electric clock display and oven control will not work. The gas burners will ignite, but the oven will not light with out the panel
This indicates the ERC Electronic Range Control has failed. First check the key pad. Press each button one at a time. You should feel or hear a click and feel the retraction. If any button is not working the problem is likely in the key pad. If you locate the tech sheet ( somewhere on the stove, usually in the control panel) it may have a ohm check that can be done on the key pad to rule out the key pad. If all seems good the control is at fault. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Sep 28, 2010 | Frigidaire FGF337EC Stainless Steel Gas...
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
F7 fault code on the Jenn-air W30400W
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps .
Mar 04, 2009 | Ovens
Maytag MER5775Q Electric Kitchen Range Logo
50 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
