Question about Vacuums
Hoover Windtunnel U6401-9RM turns it self off
This vac turns off after being turned on aprox 1 minute. What's broken and can I repair it?
Thanks!
Sal D.
  • Sal May 21, 2008
    A guess on age, 5 years old. The filter is "clean" looking but falling apart.
    Master:
  • 555 Answers
How old is this vacuum? Have you made sure that the filter is clear?
Posted on May 21, 2008
  • Matt Jurach
    Matt Jurach May 21, 2008
    It sounds like the motor is overheating, which causes the vacuum to shut off for safety. In a five-year-old vacuum, this is probably because of a worn belt.
    Your unit uses a "V-belt," which can be purchased cheaply.
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
How can I repair the "Self-propelled" selector on a Hoover Windtunnel,Model U6445? Joe
If the slector it-self is broken It's very simple to fix. If your a do it yourselfer just go or contact any vacuum repair shop and ask for that part. Or call one and sometimes they will ship it to you. If you can't find any help contact vacs.etc@live.com and we can help you.
Nov 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
It just stopped running.
This most likely is your electrical switch on the vac. you will need to take it in for repair. simple cost effective repair
Oct 26, 2009 | Hoover Vacuums
How to install the belt on the hoover self propelled vac
Video Repair instructions on installation of Hoover Windtunnel Self-Propelled vacuum ;
If you found the video helpful, please be sure to rate it by clicking the thumbs up icon below. If you have any questions about this repair, please request a clarification below.
Thank you,
Chris
Jul 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Brush won't turn and self propel doesn't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=619779
Brush won't turn and self propel doesn't work (by 2 users)
Posted by brucelk on May 24, 2008
I have replaced both the v-belt and the larger belt with Hoover brand belts and the brushes still don't turn properly and the self-propel function doesn't work. It seems that when I lower the handle all the way down toward the floor it works fine, but no one can vacuum this way. Is there an adjustment to belts to tighten them up? Otherwise I have to get it in to the only repair shop in town which is an hour's drive.X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by chartsell, posted on May 29, 2008 I have replaced both the belts as well. I have tightened the screws as someone else as suggested. The brush still will not turn unless you lower the handle almost to the ground. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. It is not so much the belts, the 2 belts are only part of the solution. The average belt change is every 4 to 6 months as a rule and to change them @ the same time. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propelled cable
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=491150
Self propelled cable (by 2 users)
Posted by raider84 on Apr 05, 2008
I can see that the cable is broken that controls the self propelled motor. But I can't figure out how to remove the top cover that will give me access to repair. Any thoughts?
X
OK
1 Other User Has the Same Problem Comment by Dr_Jake, posted on Apr 19, 2008 I also have a broken cable (or one that has come loose) and cannot find a manual to describe how to get to the lower end of the cable to make the repair. Hello,
Hoover U6616-900 Windtunnel Bagless Upright
I would contact either the local vac dealer or to contact the Hoover Factory or Manufacturer to get the owner’s manual to get an exploded view of the self propelled cable or have the email or fax the information that you need, but they should be able to send you an owner’s manual so you can try to fix it yourself. You don’t want to exceed the repairs cost to the price of what you paid for it. The decision should be yours, example: if the repairs costs are $200.00 and you paid $279.99 then @ that point you would have to decide if the repair costs are worth or do you want to pay the lower cost of repair and continue on. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 05, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
74 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
