Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP TV Component Problem-HL61A750A1F
Hi, We just purchased a 61 inch Samsung DLP tv and it is driving us crazy. The component box appears in the left hand corner of the tv at various times. Sometimes it appears during the program and other times when a commercial comes on. The technician that wired our house said the tv is switching between analog, HD or digital and this is why the box appears. We hooked the tv up to a different cable outlet and the component box did not appear once. This obviously has something to do with our home theater system because that is where the tv is plugged in when this problem happens. We had a Hitachi LCD tv with the same cable/connection and did not have a problem. (Our house and home theater system is a year old.) We have had the cable company out as well as, the tech that installed our home theater. We also exchanged the tv and still had the same problem. There has to be a simple explanation as to why this is happening but no one can give us one. We like the tv but don't like that box popping up every minute. I have been reading about different cables, HDMI and DVI but have no idea what any of that means. All of our components in the home theater are Marantz and are located in a central area. Like I said, the home theater was installed just a year ago. I'm not sure what other information you might need about our system but I can't believe we are the only ones experiencing this problem. Samsung has been no help and I can't find any information about this problem. I'm sure it is something easily fixable but we are not smart enough to figure it out. Any help you can provide would be wonderful.
  • 1 more comment
  • Reed123 May 22, 2008
    Thanks for your help.  I'm not sure why the Hitachi worked fine with the same set up but the Samsung does not. I do know that we have a CAT 5 cable with the home theater-do you think that has something to do with the problem? I'll take your advice and try a different home theater company.
  • Reed123 May 29, 2008
    In regards to the component problem with our DLP TV-all that was needed to fix the problem was a driver that we downloaded from the Samsung website and installed into the tv. Very simple solution to a problem that no one at Samsung ever suggested.
    Thanks again for the help and hopefully this info may help someone with the same problem.
  • brenda1717 Jun 22, 2008
    We are having the same problem but can't find the driver on the Samsung website. Can you tell me EXACTLY where to get it?
Posted on Jun 30, 2008
  • Samsung Master
  • 5,568 Answers
FYI only:
HDMI = High Definition Media Interface
DVI = Digital Video Interface
That kind of conflict (that's what it is) is tough for any one company to assist you on since it involves two manufacturers.
If you are very lucky, you might get help from a tech who has already stumbled across the same equipment complement.
Posted on May 21, 2008
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
Feb 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I cannot tell the difference between my SD channels and my HD channels. I have samsung DLP tv, HD cable box and bose theater system. I am using an HDMI cable but there is not difference between that and...
In most cases you will not be able to see a great difference between HDMI and Component connections. As far as not seeing a difference between HD and SD signals from your cable box, go into the settings of it and see what resolution it is putting out. If you have a Motorola cable box, with it off and the TV on press the menu button and the setup screen will appear. That will tell you the output resolution as well as what the 4:3 override is set to. Please take a few moments to rate my answer. Thanks....
Nov 22, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
61 in dlp has lines on tv
I have a DLP Samsung 61 inch. It has verticial curved wave lines, these lines seem to move. like it's not on the station good. (These lines are not black, but almost white in color.) All my other TV's in the same house, using the same sat. dish have good pictures. Could you tell me my problem and what part to look for. Thanks
Jul 21, 2009 | Samsung HL-P6163W 61" TV
Samsung HL-r4264w 42 inch dlp projection - Component inputs
I have seen that sometimes the solder becomes loose on the input board. If you are under a warranty I would call and get someone to check it out.
Apr 19, 2009 | Samsung HL-R4264W 42" DLP HDTV
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
Dec 22, 2008 | Samsung DLP HL-P5663W 56" TV
61" Samsung DLP w/ no sound
my speakers died some time ago, it wasn't worth fixing, went to a component 5.1 speaker setup. good luck.
Aug 15, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 52 inch dlp tv purchased in 2003 will not handle 1080i signal from brighthouse hddvr. states no signal detected thanks howard
Be sure you are using the correct component input
This model has three component inputs and only one (the third from left) will work on 1080i signal the first two only handle 480i and 480p
This tv will not operate with 720p signal
supertek57
Jun 17, 2008 | Televison & Video
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Samsung DLP HL-P5663W 56" TV Logo
1,094 people viewed this question
Henry  Thomas
Henry Thomas
