Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side... Problem:
Do you have any repair manual that I can use to change the fan motor on my
Samsung RS2630SH Side by Side?
  • panej May 25, 2008
    The fan you're referring to works fine but the one that is not working is the one that circulates air inside the refrigerator. There should be two of them; one in the freezer compartment and the other in the refrigerator compartment. I think they are called defrost fans or so...
I don't have one to offer, but I have removed and fixed the fan, so I can offer you these suggestions:
1. Disconnect the power.
2. The fan is located at the back of the unit behind the removable panel. The panel is held on by about 8 Phillips machine screws.
3. Disconnect the fan by unclipping the connector; simply push the tab on the front and pull straight down.
4. The whole fan assembly pulls out by sliding the fan case out towards you. It may take a bit of a pull as there are tabs holding it in. Once it's loose, you will have to turn it sideways to get it past the condenser tubing.
5. Replacement is exactly the opposite operation; the fan assembly will push into place. You'll here a click when the tabs have engaged.
Posted on May 25, 2008
  • 3 more comments
  • samsung_owne May 25, 2008
    As an additional comment, and something that probably wouldn't be in the manual, the fan itself is very simple to tear down and rebuild. There are 7 screws in total:
    1 holding the motor to the fan chassis
    2 holding the plastic motor case together
    4 long screws holding the motor armature together
    If you are experiencing a "chirping" sound coming from the fan, the most likely cause is dirt or lack of lubrication on the motor spindle. The spindle is held in 2 places, at the back, and in the middle. Once it's apart, simply lubricate with a little light grease and the chirping will stop.
    Hmmm.. last comment posted twice...
    Anyway, even more advice on disassembling the fan/motor, since we're on the topic:
    1. Make sure you note which way the motor fits on, otherwise, you might end up with the motor sticking out the wrong side.
    2.
    There's a retaining ring holding the fan to the spindle. Pull it off
    with pliers, comes right off... The fan will still be connected to the
    spindle with locktite or some sort of green glue, it just needs a bit
    of force but pulls straight off the spindle.
    3. When putting the fan blades back, don't push it too far or you might break one of the plastic tabs.
    4. Don't lubricate with graphite lubricant, you'll end up having to do the whole thing again a week later ;)
  • samsung_owne May 27, 2008
    My mistake, but the original question did not specify.
    I've only removed one of the fans from the freezer side. There are 2 plastic caps that lie flush with the surrounding plastic. These can be removed by levering them out with a sharp instrument, I used a flathead screwdriver. The screws underneath are Phillips. The two top screws of the metal panel that makes up the back of the freezer must also be removed. The entire plastic cover then just slips forward. The whole piece has styrofoam insulation holding it in place, so you may have to tug at it. The freezer fan sits right in the middle. Notice anything familiar about it? It's the same cheap motor used on the condenser coils.
    By the way, my fridge which is less than 2 years old is blinking green and not running. I called Samsung today and was told that the closest authorized repair depot is ~80 miles away! I live next to a city of 3 million people that's only about 30 miles away. I've never experienced such poor customer service.
    I will NEVER buy another Samsung product again. How this company manages to stay in business is beyond me. Warn your friends, family and anyone else you care about.
  • samsung_owne Jun 02, 2008
    Great news to report!
    I put down my $1700 for a new Kitchen Aid refrigerator!
    Samsung sent my local repair shop a new board, which they believe is also faulty... Was without a refrigerator 1 week now. While at the store (Lowes), I managed to talk 2 customers out of buying a Samsung washer/dryer and stove/refrigerator. I figured that was worth ~$5000 in lost sales. In all honesty I believe that I did these people a great service. I only wish someone had warned me about Samsung appliances and service before I spent $1200 on their garbage.
Sir - thank you for the posting above. You have single-handedly prevented me from being committed to the asylum. I just completed taking the fan assembly out, apart, cleaned it and oiled it. She's not squeeking anymore.
Posted on Nov 28, 2011
Displaying OF on screen Cannot find in the manual
not to sure maybe open fan motor.So fan motor faulty.
Jan 10, 2016 | Samsung RS2630SH Side by Side Refrigerator
My samsung side by side power cool alarm wont stop sounding. I have changed filter but temperature will not stop decreasing
Alarm tells you about a problem. Does it give you a fault code?
Is it cold in the freezer? Please check if there is build up of ice in the freezer rear wall. Check the evaporator fan motor.
Feb 27, 2015 | Samsung RS2630SH Side by Side Refrigerator
Samsung refrig fan noise-sounds like cricket.
sounds like the bearing is starting to get tight in the fan motor. i would replace the fan motor.
Oct 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Door heater
this isnt an electric heater in between the doors its a hot gas loop. there is a motor behind the refrig that cools the comp and condenser coils this fan is either not working or something has jammed it up. just pull the refig away from the wall remove the compartmnet cover and check that fan out good luck peyton
Jan 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Refrigerator
You have the fan problem. Full the refrigerator out and open the lower back cover you will see you fan is almost become bad. If you apply WD1040 oil you can use it about 3 more months. Then It will die out. I think you better change it now or later on you refrigerator become hot and hotter. If you are careless, you can get burn you skin. I had this problem. Frist, the fan made noise on and off. I applied oil into the motor. It was working about 3 months then I died out. The front end of refrigerator become a heater.
Go to online partstore.com and buy a fan with your fan model.
Dec 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Multiple Ongoing Problems w/ Samsung RS2630SH
noise from the back .. outside ? would be the fan motor DC ver-speed motors.. frosting over is likely a drain problem
Aug 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Noise
the condenser fan motor is the culprit of the problem. all u have to do is replace it with a new one it would cost about 60 dollars
Feb 26, 2008 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
SAmsung Service Manual
I fixed my problem with the fan not working in the refrigerator section. It ended up being the fan motor. The way I nailed it down was to temporarily switch the wires to the fan motors in the connector on the circuit card. This electrically powered the freezer fan from the refrigerator side and visa versa. The fan still worked in the freezer side (running of the refrigerator circuit) and was still inop on the refrigerator side proving that there was nothing wrong with the circuit card or possible other factors driving that circuit (other than the fan motor). I ordered and installed a new fan motor (about $50) and now everything works fine. It seems that the original problem caused the circuit card to shut down voltage to the bad fan motor that's why when you checked the voltage from the circuit card, it was nill causing you to falsely believe that it was not the fan motor. Yes, I did a resistance check on the fan motor and it was very close to being the same as the freezer motor (same part number).
Jun 03, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
1,567 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
