Question about Bissell 3522 PowerForce Bagged Upright Vacuum
How to replace a belt successfully on a Bissel Powrforce 3522?
I just replaced a new belt. Style 7 belt. But when I turned on the vaccumn, my brand new belt broke, like 5 seconds after turned it on. It had this smokey smell. I guess I put the belt in wrong, how exactly do you put the belt in?
  • 1 more comment
  • commonproble May 26, 2008
    I have the same problem, but can't figure out anything to try to fix it. The belt looks like it's in there right. I don't want to start the vacuum upside down with the coverplate off to see what's happening because I'm afraid the belt and roller will fly out and hit me in the face. I inherited the vacuum from a neighbor moving out who said it just needed a new belt. I guess you haven't come up with a solution?
  • Mary Short Aug 04, 2008
    I have had the vacuum for about 4l years. It worked great for awhile and then the belt broke. I got a replacement belt but after short time it comes off. It is a Bissell belt, correct size, etc. I put it back on( a pain) and it slips off again. I can even turn the brush and watch it work it's way off the bar even before I put the cover back on. It should have alot of use left but this is rediculus!
  • lakendal15 Nov 11, 2008
    belt broke, when i put the new belt on i smelled burning and the new belt broke, how do i put the new belt on without it breaking?
How do I replace the belt? I don't know how to get into that area.
Posted on Sep 29, 2008
Can you fuse the belt back together on a bissel shamppoer power steamer
Jolene,
I have done some fusing of belts in the past and did not have real good success in doing so. I would recommend finding a replacement belt and put it on.
Nov 10, 2014 | Vacuums
Bissel roller not turning
Hey, brush not turning can be quite frustrating. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1449&cid=ccsocial
Feb 12, 2013 | Bissell 3522 PowerForce Bagged Upright...
How do I change the belt on a Bissell Powerforce model 3522-1?
this is how you do it Lower handle and place vacuum on floor so you can see bottom of power head. Examine the power head to remember what it should look like when finished. Unscrew the four screws (Phillips screwdriver). Lift off cover. Lift out brush. Remove belt from brush and motor shaft. Place new belt around motor shaft, then around brush just prior to reinserting brush. Make sure the belt is placed correctly. Reinsert brush in slots. Rotate manually toward motor a few time to center the belt. Replace cover and screws. Tighten securely. Check cover to make sure it's properly secured.
Feb 16, 2011 | Bissell 3522 PowerForce Bagged Upright...
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
Brush heads won't spin
Your belt is stretched, worn or broken and therefore not turning the brush. Here is a link for the replacement belts you need and the manual which has instructions:
Bissell PowerForce Replacement Belts
Nov 17, 2009 | Bissell 3522 PowerForce Bagged Upright...
BISSELL 3595-D CLEARVIEW REVOLUTION UPRIGHT VACUME
Target has replacement belts. In the manuel, it will tell you the size. 7-9-10 Drivebelt
Jan 03, 2009 | Bissell 3522 PowerForce Bagged Upright...
No cleaning fluid or water comming out of cleaner
not sure of your model but on most of the bissell's ( except there new style) the belt drives the pump and the brush on the bottom. no pump action then no spray action. you probably need a new belt.
Sep 03, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuum is burning through the belt.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=789867
Posted by slhb on Jul 16, 2008
I have replaced my Eureka Ultima Belt (with style U) and when I turn the vacuum on to use it, it immediately burns through the brand new belt and therefore does not work. I have tried three separate belts, but it does this each time.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. According to what you have said I can see maybe 2 problems, either your brushroll or bearings are froze up or you have a build up of thread and hair on the bearing ends. The brushroll should be free spinning or #2. Your motor and pulley could be bound up and or shot and might need replacement. Check to see if the motor pulley spins freely and if it does then it almost has to be the brushroll and would need rebuilding or replacement. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 16, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell power force
turn vac over, take of the access plate covering the brush roll, may be 2 to 4 screw. Then you can get to the brush roll and belt. It uses a Bissell Style 7 belt.
Jan 09, 2008 | Bissell 3522 PowerForce Bagged Upright...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
432 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
