Question about Microsoft Windows XP Home Edition
Insufficient memory When trying to past from an internet website into word I keep getting an insufficient memory or disk space error. I have done this many times before and never had this error. Can you suggest a solution.
How much free (HDD) space do you have, both in GB and percentage? If you have a small HDD or it is over 90% full, then those facts need to be considered. Also how much RAM do you have?
What programs were added since you last went from one application to the other and it worked without a problem? Or did you add something big to the HDD? If you have more than one HDD, please post such info for all of them.
Any chance you know how to check your virtual memory settings, to report them here?
Posted on May 22, 2008
    Problem Solver:
  • 7 Answers
Know that if you want to resolve this problem you at first set off some resident programs on your pc then you will have more space or it could be caused by some virus program!!
Posted on May 21, 2008
Insufficient Memory in Adobe Illustrator
It is obvious your scratch disk does not have enough space. I would say that truth about the memory problem is the Very Critical Memory Bug that comes with CS4. You can try to disable all the apps that are running at the same time, but the problem can be still here. Installing of a current AI version might help. Also try to save a TIF of the image in Photoshop, it could be a quick fix to the problem. Or reduced the pixels number.
If nothing helps, use a special software that is able to recover it. There are a lot of on network, but unfortunately not all of them are so good. Try Recovery Toolbox for Illustrator https://illustrator.recoverytoolbox.com/
Oh, also i've remembered one method: Unlock all the layers and 'select all' and 'copy'. Than create a new doc and paste your image in there. Save the document with a new name.
Mar 25, 2015 | Adobe Systems Incorporated Illustrator CS4
Laptop runs slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Feb 17, 2013 | Packard Bell Easy One Silver 2101 Notebook
I have 88GB free disk space. I am using CaptureEze97 and get the following error when capturing an image: Insufficient disk space to perform selected operation. Free disk space before continuing.
Glad to HELP YOU!
You get that error message because your CaptureEZE is building up some TEMPORARY FILES before it will depose the right files on your hard drive. That means it needs EXTRA ROOM on your HDD.
So get rid of some useless/not used files or applications.
Also perform a DISK DEFRAGMENTATION and a DISK CLEANING using the reources that Windows provides you.
Go START > ALL PROGRAMS > ACCESSORIES > DISK TOOLS and first select
DISK CLEANUP and wait for the operation to be done;
then select DISK DEFRAGMENTER and let the operation to be performed.
GOOD LUCK!
Apr 15, 2011 | Computers & Internet
How do i clear the memory on my aculaser C900? It is coming up with error message 'unable to print insufficient memory'
You need to free some space in your HARD DISK C: DRIVE. because he needs memory to print documents
Dec 08, 2010 | Epson AcuLaser C900 Printer
My computer shuts down in the middle of the game (Toontown)
Try to uninstall the program and reinstall it. Normally, this happens due to insufficient memory resources like video memory is insufficient and the system RAM.
May 08, 2009 | Disney Interactive Disney's Toontown...
Lsass.exe error insufficient system resources exist to complete the API. what can i do to fix that. thanks
how to remove ISASS.EXE SYSTAM ERROR INSUFFICIENT SYSTEM RESOURCES EXIST TO COMPLETE THE API
May 28, 2008 | Apple MacBook Pro PC Notebook
Insufficient memory
Check you disk space. [my computer] right click on Local Disk C. im a begginer myself, so i dont know much, and i cant help you a lot.
Apr 29, 2008 | Ulead VideoStudio 9
Insufficient Temporary Disk Space Error
Find out where it wants to store the temp files, it may need to be changed tc c:\my documents for example.
Dec 19, 2006 | Harmonic Vision Music Ace for PC, Mac
Error Message
I had the same problem.Adding twain_32.dll to the Windowsfolder solved the problem.For people who don't want to search for it: Look Here.
Then you won't get this error but one saying to reinstall the printer driver. Just do it and the problem is solved.
Nov 28, 2006 | Canon PIXMA MP150 All-In-One InkJet...
Microsoft Windows XP Home Edition Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
