Toshiba 35 inch picture tube problem
The picture on the screen is only about 6- 8 inches tall, not the entire picture tube size. Do you think the problem is the tube is going out or might it be related to a controller card? Thanks
  • Anonymous Mar 12, 2009
    the picture is shrinking, started off with a blk horizontal line, now there is only about 2 inches visible, the sound is good.
    Problem Solver:
  • 7 Answers
HELOO THE SET IS HAVINGA VERTICAL FAILURE ,REPLACE THE CONDENSERS AND ANY BURN PARST IN VERTICAL SECTION.AND AT LAST REPLACE VERTICAL IC IT WILL BE OKKK.
Posted on May 22, 2008
MAX SIZE OF MY PICTURE 25 MB IN INCHES
...???? 25MB does not relate to inches... its all relative to "pixel count" size...so it depends on what "size" the default format is... a 25MB picture in 400 x 600 pixels (EXAMPLE= 40 inches by 60 inches) will be GIANT.. while a 25MB picture in 4000 X 6000 pixels (4 inches by 6 inches) will be 10x smaller - SIGNIFICANTLY smaller in inches
Aug 07, 2017 | Max Computers & Internet
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Adjust resolution on lumix dmc-tz3
Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
Toshiba 32 inch 8year old tv set
Probably a bad connection on the tube base but your CF32H50 model dates from 1998!
Jan 28, 2018 | Toshiba CF32G40 32" TV
Burnt item RCA P56830BL
Can you give me the PCboard location number of the component? It will be stamped on the PC board where the component is located.
May 24, 2008 | Televison & Video
Two green lines on bottom left corner
Sounds like a convergance issue. I would have a tech set the convergance for you if you have not done it before, it can be tricky and you could make worse.
May 11, 2008 | Toshiba 65HM167 65" Projection Television
Standard CRT Toshiba TV - 4inch tall picture in middle of screen...
Not familiar with your actual model.
But a comon problem with older Tosh sets is the 2.2uf electrolytic caps from memory they are usually red there is 1 next to frame Ic & the second is near Psu.
Allso check frame o/p IC for dry solder joints this is easy to test for.
Tap the tv while it is on if the the frame suddenly pop to full size picture you know its dry joints so resolder frame IC.
http://dysonmanuals.inc.io/
Oct 13, 2007 | Televison & Video
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba cx35f70 35"
It could be a bad solder connection on either the crt drive board that attaches to the neck of the picture tube, the video processing circuits on the main printed circuit board or the picture tube itself. If you can lightly bang the sides or top of the set to get the symptom to come/go, then it is most likely a bad connectiion. If, when the screen goes green, you see fine white lines diagnonally across the screen about a half inch apart, then it is likely the picture tube.
Jan 18, 2007 | Toshiba CX35F70 35" TV
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
