Question about Toshiba Qosmio G25-AV513 Notebook
Laptop problem i have toshiba Qosmia G30 ,now its display havery big green squares in large quantity also on monitor attach same problem shows on monitor help me out
    Problem Solver:
  • 6 Answers
Sorry, video drivers will not solve this. This is a known hardware issue. The only "apparent" fix is to send it to toshiba if under warranty or replace the motherboard yourself.
http://tais-app-p01.toshiba.com:8080/KanisaPlatform/Publishing/672/1199_f.html
Posted on Jul 16, 2009
    Guru:
  • 1,342 Answers
Click HERE to go to Toshiba's web site. Click on Download Drivers, select your model and operating system and update your video driver.
Posted on May 21, 2008
Toshiba Qosmio G30 Flashing DC- In LED on power up and cannot start laptop
I found some G30 with defective memory and it cause boot up problem. You can try to remove one memory to test it. Testing the laptop with a good working memory is the best way.
Feb 06, 2014 | Toshiba Qosmio G30-166 Laptop AC Power...
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
My screen on my laptop coming up green can you help please
Your screen is bad or the video card inside the laptop is bad. More than likely it's the screen. To isolate the problem try connecting an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If it display ok on the external monitor that proves your video card is ok but your lcd screen is bad. If it displays the same as your lcd screen, then your video card has an issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display on it.
Jun 05, 2012 | Toshiba Computers & Internet
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
Toshiba lap top half screen rainbow lines
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the rainbow lines, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same rainbow lines it means your video card inside the computer has the issue.
May 18, 2012 | Toshiba Satellite M35X-S149 Notebook
Toshiba satelite pro red spot on screen
Sounds like your screen is going bad or your video card is bad. Try plugging an external monitor to the laptop to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it into the laptop. if the borrowed monitor displays without the red spot then your original monitor is bad. If the borrowed monitor shows the red spot then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 12, 2012 | Computers & Internet
Viewsonic monitor lcd to laptop problem
Remove the second monitor entry in Device Manager, and let the machine try to find the driver. I swear, sometimes, computers have minds of their own! ??
Apr 04, 2017 | Computers & Internet
I want to get the screen from my laptop(toshiba) to show on a....
press Fn key 2 times set display property screen resolution to 1024*768 then apply and ok.
Jul 14, 2009 | Toshiba Satellite 3000-S353 3005-S303, and...
Partial lcd display on laptop
Hi
Sometimes the resolution changes to an unusual setting when an external monitor is attached. make the LCD screen your main monitor and change the resolution to 1024x768 or 600x800 whichever is best.
Happy to help
CBZ
Apr 25, 2009 | Toshiba Tecra A4-S313 Notebook
Graphics card has failed on Toshiba Qosmio G30-175
the graphic card of qosmio g30 is built in to the board you need to change a mother board of your computer this is the dis advantage of g30 or you buy a pci videocard and plug in but the monitor of you laptop is become useless bcause you need to plug in a external monitor to the pci videocard..
thnx
bochard
Mar 24, 2009 | Computers & Internet
Toshiba Qosmio G25-AV513 Notebook Logo
147 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
