Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Philips 55pp8620 red multipoint manual con...
By phillW on May 21, 2008
Hi all, The red multipoint manual converg. on my tv has portions of the screen that will not adjust and the cross hairs are way off in these areas. It affects maybe 10 of the adjustments zones, mostly top left and bottom left of the screen.
As a result the picture "bends" in these areas and theres a distinct red shadow, Blue seems to be 100% fine at the moment.
Same Problem
Dec 13, 2008
-   I have a 55PP9352 rear projection TV that has recently displayed the same issue: multi-point red crosshairs can't be aligned on top and bottom left portion of the screen.-   Guest
Dec 05, 2008
-   my phililps tv red multipiont is not working-   killerinsik
Jul 07, 2008
-   I have a Philips 55PP9502 that has the same exact problem w/ red convergence in the same area upper left and bottom left. This problem started less than a week ago and set worked fine prior to this. Any thoughts , help would be appreciated.-   Guest
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
my tv (panasonic pt-50lc13) shuts it's selfoff the power button flashes red and the lamp light is... (More)
Answer
picture looks as if you were looking at it thru infared
Answer
My 1996 Mitsubishi Diamondvision 50" tv worked fine up until last year. The picture started... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
