Question about GE 106591 Coffee Maker
GE Cofee MAker Model: 169164
Don't warm up / brew... press power botton and wait a minute or so and get back two (2) Beeps...
  • 3 more comments
  • Anonymous May 27, 2008
    HI. THE COFFEE I BREW TASTES VERY WEAK EVEN THOUGH I SEEM TO USE ENOUGH COFFEE. ANY TIPS ?
  • Anonymous Aug 25, 2008
    Purchased this model and also have the same problem of weak coffee. I researched the problem and came to the conclusion that the drip head holes miss the coffee grind completely with most of the water running along the outside of the strainer. To confirm this, I manually ran the brewed coffee back through the grinds. The end result was bolder, stronger coffee. The drip head appears to be the problem. I tried placing a paper filter into the strainer first then the grounds. This helped but it's still a design flaw.
  • trulyw Dec 27, 2008
    how to set timer on a ge coffee maker model 169164
  • sheilapan444 Jan 21, 2009
    My coffee pot worked this morning. Got home this afternoon with hopes of having a hot cup of coffee, went to prepare the pot, pused the button and nothing. does not brew. Any suggestions to this? I got the pot in November 2008 so it should still but under warrenty right? I have the box, but no recept as that it was a gift.
  • lynnfraz Feb 04, 2009
    I purchased this same coffee maker last week. Got it home and went to clean and run water thru it to rinse out before using, as per instructions. Nothing would happen...no water going thru, not heating up. After trying for a few minutes, the clean light came on and would never go off, even after 3 hours. I took this back to WalMart and exchanged it. After getting the second one home it ocurred to me that the first one I had must have been returned to the store once before, as the charcoal filter had already been put in the holder and there was no cardboard on the hot plate as there was with the 2nd one. Gee...someone else must have had problems. Anyway, I ran water thru the new one with new problem, made my coffee for the next morning and had coffee when I got up. HOWEVER...I came home from work yesterday afternoon and went to make a pot of coffee and low and behold, nothing happens when I push the button once again. No water goes thru, hot plate doesn't heat up, no coffee. Guess I'll be taking this one back and getting another brand. I so liked this one and the features, but reading all the other complaints, it's nice to know I'm not alone on this.
Thanks...
I actually did call customer services @ 1 877 207 0923 (Option 4) and give them the model (169164). They suggested that I should take back and got a replacement, since still under warranty period, won't cost me a penny more...
Anyhow.. thks for the suggestion...
Posted on May 22, 2008
  • GE Master
  • 5,568 Answers
Most failures of coffee makers are related to thermal fuses which have opened and interrupted the current flow to the heating element.
Often, they failed for no particular reason but replacing the fuses would probably cost as much as tossing the whole machine.
Yeah, I know, I don't like it either.
Before retirement, I earned my living fixing stuff we can now buy cheaper new.
Posted on May 21, 2008
My Coffee maker is not brewing, and the screen says de-scale. I don't know what to do, I remove the water container, turned it off and back on. I will appreciate your help, thanks Andrea
Step 1: Plug Brewer in and turn power "ON".
Step 2: Pour approximately 64 oz of the vinegar into the Brewer until 4 beeps signal the tank is full.
Step 3: Wait about 6 - 8 minutes for the vinegar to heat up and the green "READY" light to go on.
Step 4: Place a ceramic mug in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP...just press the Brew button.
Step 5: Repeat the brew process 4 or 5 times pouring the contents of the mug back into the Brewer after each cycle.
Step 6: Now let the Brewer stand for 4 hours while still on.
Step 7: Place a ceramic mug on the Drip Tray and run 4 brew cycles, pouring the contents of the mug into the sink after each cycle.
Step 8: Turn the brewer off, let the remaining vinegar cool, and drain the brewer as instructed above.
CAUTION: Vinegar may still be hot. Remember to replace the Drain Cap.
c. RINSE
Step 1: Fill the brewer with hot tap water.
Step 2: Power up brewer.
Step 3: Wait about 6-8 minutes for the water to heat up and the Green "Ready" Light to go on.
Step 4: Place a ceramic mug on the Drip Tray and run a brew cycle.
Step 5: Repeat brew process 4 times for a total of 5 cycles.
Step 6: Drain the brewer as instructed above.
CAUTION: Water may be hot. Remember to replace the Drain Cap.
Step 7: You may need to rinse again to eliminate any residual taste.
http://www.keurig.com/Customer-Service/Brewer-Registration-And-Support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions_04_30_2004.ashx
Jun 06, 2011 | Keurig Platinum B70 Coffee Maker
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
Nov 01, 2009 | GE 106591 Coffee Maker
Error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Mar 05, 2009 | GE 106591 Coffee Maker
GE Model 169164 stops brewing
A couple of people on here mentioned he filtration system, or charcoal filter that is in the
water resovoir as being problematic. We removed it. This morning the pot brewed entirely.
Not sure how that all is inter-connected, but it worked.
Feb 04, 2009 | GE 106591 Coffee Maker
Past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Jan 27, 2009 | GE 106591 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Coffee maker clicks but does not brew
This information is for the GE model number 169164 12 cup digital coffee maker.
The Micro fuse is shorted open. There are two underneath the housing. They are made by MICROTEMP® and are the G400 series rated at 216 Degrees Centigrade.
You can check these with a Ohm meter to see if you have continuity. Checking across the leads of each one they should show infinity. If not you've identified the bad one. You can pick up a new thermal fuse at Radio Shack. The closest one to the specs of the Microtemp is a Radio Shack part number 270-1321 rated at 228 Degrees Centigrade. Before removing the old one notice which way the hat end faces.
Use a heat sink when soldering the new thermal fuse in place by using alligator clips or a pair of pliers.Reassemble and your back in business as a Barista.
Note: There are four Phillips head screws under the rubber pads. The three unusual screw heads may be removed/installed with a small screwdriver installed in just one of the slots.
Nov 16, 2008 | GE 106591 Coffee Maker
GE Model 169164 Paper Filter Size?
# 4 coffee filters made by militta. I have the same maker and i hate all the coffee grinds in the pot
Oct 20, 2008 | GE 106591 Coffee Maker
GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Aug 01, 2008 | GE 106591 Coffee Maker
GE 106591 Coffee Maker Logo
836 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
