Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Pt-44lcx65 As I receive the message to clean the fan filter, per your notes I am trying restore the tv so I can watch it without the sutdown message, and to get to the reset function you say to go to the service mode by press the vol- onb the tv and the tv/video remote key at the same time. This seems to work, but I cant get the next step, press the stop/swap part to work. It does nothing and I cant seem to get into anyscreen that has anything to do with the fan filter or reset. Can you please help thanks Marty
  • 19 Answers
You have to hold the Stop/Swap button for 7 seconds.
Posted on Jul 01, 2008
How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Apr 18, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic pt-44lcx65
The fix for the air filter problem also you are probably getting the on screen message clogged filter also. It can be repaired by relacing the light engine (VERY EXPENSIVE) or remove the light engine and clean the filter much less cost infact none if you know how.
To clean the filter you must remove light engine and you will see at the top a black housing with two screws that must be removed to remove light engine.
A service maual on how to remove light engine is very helpful wich can be ordered on the internet. Any way you want to remove 4 screws from the housing you will then see the filter and 4 more screws to remove in all four corners, remove the screws and then pry the rectangular filter out of the assembly. This may take some effert so be careful. Look at filter through light it will probably be dirty wash with water and blow it out with comprssed air look at it through to insure it is clean then reinstall .Reassemble and you should be good to go.
Jan 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Were is the air filter?
The air filter is in front of the tv pop off the front and it is in a screwed panel you can take it off but i vac it out and air dust it out and it works great u need to not smoke around the tv or burn candles around it hope it helps
Jan 07, 2009 | Panasonic PT-44LCX65 Television
Panasonic
The air filter should be a user-accessible thing. Consult your owners manual for details. Can you find the manual?
Dec 30, 2008 | Panasonic PT-44LCX65 Television
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Computer vga to tv
I'm guessing you've resolved this by now, but, if this is a laptop computer, it is actually a function of the computer that you are looking for and not the TV. Typically there is a key function assigned to directing the display to the laptop only, the tv only, or both simultaneously. On my current laptop it is fn+F8. On my old Dell I think it was ctrl+F8
Hope this helps, sorry so late.
Aug 06, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 Projection TV
There is a filter in the front of the machine, right beside the lamp door theres another one. blow that out with can air will kill the error for a while then you might needs to get it serviced because one of the fans is caked with dirt and if you dont know electronics i would not try to take it apart to clean it.
Mar 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
