Question about Panasonic PV-DF2703 Triple Play 27 in. TV/VCR/DVD Combo
Blach rectangle bottom halfpart of screen
Seconds after turn on tv a black rectangle fills most of the bottom half of the screen. It goes away when I prees the audio or surround sound button but it comes right back. I also noticed that if I press the mute button the subtitles don't come on like it used to. The tv is 3 years old
    Novelist:
    Scholar:
  • 100 Answers
Salutations bachiche13,
It sounds like your "Text" feature of your closed captioning may be activated. It sounds like what you would want to do is go in to your television menu and select CC or Closed Captioning to mute or off.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 21, 2008
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
I have a 05 jvc tv 32 inch . I lost my remote temporarily-used the menu on the actual TV to set a timer for the TV to go OFF-turned it on this AM and now i have half of my screen filled with this overlay ....
Try Reseting It Unplug It For 30 Seconds And Then Release And Plug It Back In Once You Go To Turn It On Hold The On/off For 10 Seconds and Then Release. This Will Hopefully Restore The Factory Setting And You Can Determine If Its A User Setting Or Hardware Problem.
Jan 23, 2009 | Televison & Video
Black rectangle on screen
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Jan 20, 2009 | Disney 13" TV
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Black rectangle
If the black rectangle is in the middle'please check to see that the closed caption is not activated.If not please provide the location of the rectangle.
Jan 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Black on lower half of screen
This type of problems and some OSD problems are occurs due to microprocessor over modulation. One option is there. That is if you have any child lock or keypad lock or frontpanel lock. First locked the system. Now check your problem arise. If it is not OK. Otherwise try to find nearby any radio frequency cable across in your tv. keep away that cablewire also. your problem solved. Even you get Call your nearst service provider..
Aug 23, 2007 | JVC AV32F577 32" TV
Black Rectangle Appears on Screen
Perhaps the caption is on?
May 27, 2007 | JVC AV-27220 TV
Panasonic PV-DF2703 Triple Play 27 in. TV/VCR/DVD Combo Logo
139 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
