Question about Karcher 2500 PSI Pressure Washer
Choke needs to be on all the time
I bought a new G 2600PH Karcher 2 weeks ago, and it runs fine and works fine. But I can never push the choke back in or it immediately dies (Honda engine). Karcher say I need to bring it back and replace it. This would be a real hassle for me. Any ideas?
If I need to run it with choke always out, does this damage it in any way - does it consume more fuel, create more CO2, shorten the engine life in any way?
Thanks
  • mike_442 May 28, 2008
    I'm having the same problem with my 2500vh? I have never been able to put my choke all the way in, but it seems to be worse this year finding the sweet spot for the choke. Any resolution from anyone??
  • gasman10 Sep 03, 2008
    I have same problem. Removed and cleaned carb but still same results. I noticed that if I spray carb cleaner while it is running near the throttle valve shaft at the top of the carb, it seems to run good for about 5 seconds and then gets rough again.
  • 33 Answers
Your problem is in the carb. for some reason there is a stoppage or clogg in the venture opening that feeds the main passage to the manifold. that is the little pipe connecting the carb to the engine.the choke being on causes the engine vaccum to **** gas from other resourses in the carb to run. also check to see if throttle butter fly is moving freely.there may be a defect with the carb and they will have to replace. running the engine with choke on causes it to run rich and will foul the plug eventually . also not good on gas . will use way more than it should. also co2 level way up.
Posted on Apr 21, 2009
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Jan 04, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
I have a mtd 3.5hp 21" snow blower it was bought new in 11/06 the problem im having is stalling it starts ok some times other times it stalls and won't run others it will only run at full choke if...
Try running some fuel system cleaner through it. A good choice is Chem Tools Berryman B-12. There are some hardworking solvents in the product that could help you overcome a dirty carburetor. Initially use a good, strong dose. Maybe double what they recommend . (1 oz/gallon). If this doesn't work, the carb will probably need to be removed and inspected and cleaned.
Feb 03, 2011 | Garden
Last time I STARTED MY VSTAR 1100 I CHOKED IT FOR 10 SECONDS ON HIGH THEN MOVED TO MEDIUM CHOKE FOR 4 THEN TOOK OFF AT NO CHOKE. 2 WEEKS LATER. I started up bike Choke on high bike barely wanted to idle...
Sounds like your flooding it out with the choke out. Try the next time you go to start the bike when it's cold with the choke out and when it starts push the choke all the way in and keep it running with the throtle. If it runs better after doing this then your flooding it on start up. Use 1/2 choke to start cold and see what it does. Good Luck
Sep 29, 2009 | 2001 Yamaha V Star Classic
2006 Honda Shadow Aero starts but won't idle.
check fuel level, u may need to check the flow of petrol to it,,Also if that does not solve you may need to service the carb and check fuel filter,air filter etc...
Aug 31, 2009 | 1999 Honda VT 1100 C3 Shadow Aero
Cbr 125 choke problem
It sounds like the choke line may not have been routed correctly when the new one was installed. Remove the gas tank and check to see that the line is not being stretched anywhere along the way AND that the gas tank when re-installed is not stretching the line. The line may have been kinked when installed. Look at the mechanical movement of the choke at the carb. Does it operate freely? Remove the air filter and look inside the center of the carb, (you may need to use a small mirror for this), does it look like the choke is opening and closing properly when the choke is moved on and off?
Mar 13, 2009 | 2004 Honda CBR 125 R
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
531 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
