Question about Gateway FPD2275W LCD Monitor
Monitor failure Hi I have a Istar mod ID-17BSSIL monitor that is intermittent when first turned on. Sometimes it will work but mainly it starts and then stops after a short time during runup. Initially, switching it off and then on, rectified the problem but now it fails almost everytime I try and use it. Thanks, Jeff
  • Jeff Staines May 30, 2008
    Thanks for answering. My computer works fine with another monitor and the faulty monitor behaves the same on another computer so I'm 100% (maybe?) certain it's the monitor. I'm a TV tech from way back so I have an idea about fault finding, however I've never worked on this type of equipent. Any hints you might give me would be gratefully appreciated.
    Jeff
  • Jeff Staines May 31, 2008
    Thanks for trying
    Jeff
    Sergeant:
  • 458 Answers
Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor.
Posted on May 30, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Tech T.V. That brings back memories.
    As they would probably tell you. Monitors are very dangerous. The cost of a new monitor is not as much as your life is if it kills you to try ti repair it yourself. Capacitors inside of the monitors can hold power for a long time even when it is uplugged. I personally do not try to repaire dead monitors, and the only people that could are T.V. Technitions. Best thing to tell you wuold be to call a T.V. person, but the cost will be not worth it. Good luck and do not kill yourself.
Intermittent picture on turn on - constant volume
Hi Ronni McClare,
For better assistance you can contact our Baby Monitors specialist.
http://www.motorolacordless.us/
Best Regards,
Katy
Motorola Support
Feb 24, 2014 | Motorola Mobility Mbp35bl Digital Video...
Intermittent external monitor failure
get anther monitor not many engineers tamper with them there surjestion is to replace the monitor
May 10, 2012 | Apple MacBookAir A1370 -19648
Tv monitor will not turn on sometimes.The power light will blink but not go on.
Do you mean that your set operates sometimes and other times it won't? If it's never working and the power light is blinking that would indicate there is a failure in the power supply or the deflection circuitry. Either of which is not an easy fix. If it works normally sometimes and not others it indicates that you have an intermittent problem which is usually caused by failed soldered connections someplace on the main board.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hi My atlas monitor has begun to intermittently
intermittent problem most likely caused by a faulty patient cable with is the cable that goes from the monitor to the sensor. could be a problem in the cable itself or the connecters on the cable. best bet is to try swapping a known good cable but make sure it is the right part number. Some cables will fit but not work right. i can offer more help at info@mesasales.com I can supply new cables if nessesary.
Aug 07, 2009 | Welch Allyn Atlas Monitor W/Ecg, Nellcor...
My Envision 7100 Stop Working
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Jan 09, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
No Power
Turn off the monitor (and for safety the pc). Unplug the monitor from the PC. check the cable and the port for dust or particles. Check the whole cable from end to end for any tearing of the sheeth. Have any pets that like to chew things by chance? This may help us get started. If you blow on the cable end and the port on the PC, that may due the trick. It may also release any static charge that could have built up.
Dec 16, 2007 | Computers & Internet
NEC P1250+ hisses and scrren blips intermittently
I had the same problem. Your monitor is warning you of failure. The hissing sound is the picture tube powering up. The momentary blank screen is when the power supply for the monitor has become hot. Your monitor is getting ready to quit. My suggestion is to buy a new monitor. To have a tech repair it would be more expensive then buying a new one.
Sep 19, 2007 | NEC MultiSync P1250 Plus (White) 21" CRT...
EV 700
my gateway monitor makes a sqreeching noises when you turn it on. after that it starts making that noise like it does when its fixing to come on then it starts smelling like its burning then we turn it off. please help
Oct 18, 2006 | Gateway EV 700 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
