1993 Geo Metro Logo
Posted on Sep 24, 2010
Temp Gage while on local streets seems okay. When I take it on freeway within. A few mnutes Gage is at. Red like its. Overheating. Although. Cars performance seems the same. Check under Hood radiator a bit hotter than norm. But everything seems alright
Anonymous
Level 1:
  • Contributor 613 Answers
  • Posted on Sep 24, 2010
Anonymous
Contributor
Level 1:
Answers
613
Questions
Helped
167916
Points
35
Sounds like the thermostat is staying closed or maybe a leak in one of the hoses id check it and if no loss of fluid and the antfreeze is topped off then id replace the thermostat see if fixes it make sure get the thermostat gasket too like 6 bucks for both
My 98 Olds Silhouette van shows to be overheating, and the 2 radiator fans aren't coming on. Help!
The first thing I would check is the fuse associated with these fans. If that is ok then I would suspect the temperature sensor that controls the fans.
Auto coolant hot temp light comes on and temp gauge goes up more when idling at a light
If temp gauge is going into the red on a 3.4 engine it must be shut down or head damage can happen within minutes. I have a Monte Carlo that was overheating. I changed everything, thermostat, water pump, belt tensioner, radiator, all with no result. It would start out okay on a cold start but then I would come to a red light and the temp would creep up. Higher and higher until it neared the red zone. The heat would run cold. Most of the time, as soon as it was about to touch the red it would start to drop, the heat would blow hot again and all seemed okay but not for long. This would get worse and worse until the red hot light came on and I found myself on the side of the thruway. This problem is a blown head gasket. I had no other obvious signs, no white smoke from the exhaust, no oil in the antifreeze. I even changed the intake gaskets. Head gasket issues are common on the 3.4 liter engines.
1helpful
Hello, My trailblazer was overheating to hottest few days ago! first I replaced the thermostat, the problem was going on so I replaced water pump, fan clutch, checked and cleaned radiator three times and...
check for a blown head gasket, do a compression test on all the cylinders, they should all check out to about the same , if 2 are off you have a bad gasket
1helpful
3answers
Two things come to mind, after each refilling of coolant did you "burp" the system to make sure there was no air trapped? And second, you may want to have the coolant checked for exhaust gases in case there is a headgasket leak into the coolant.
2helpful
My 2002 Saturn SC2's temperature gauge goes into the red when I idle at a stoplight too long or in the drive thru at the bank. It never does this when driving on the street or freeway. I've had the...
Be very careful as overheating can cause permanent damage to the head gasket.Now whenever an engine temp reaches half then the fan should start,so watch if this is working.Allow engine to run and watch the temp gauge goes up..Once it is half then the fan should start, if it does not replace thermostat..Else watch the radiator as it may be blocked.
My car has antifreeze in it but after driving it, the engine is all hot. what's wrong with it? help please
If it gets hot at high speed such as freeway driving, but seem okay at street driving, It is the radiator. If it gets hot really quick at any driving condition, it could be the thermostat. Since there is no leak, the last possiblity, and also least likely is an extremely retarded timing. Lastly any kind of leak will cause an overheating problem, but from your info, it don't have a leak.
Temp Gage shoots up and down
POSSIBLY A FAULTY THERMOSTAT
Top Geo Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Geo Expert? Answer questions, earn points and help others
