Question about Gateway MT6707 Notebook PC
Gateway mt6707 How do I disassemble my mt6707 to be able to fix my dc power plugin. the soder came loose.
  • 2 more comments
  • Harwick May 31, 2008
    My Gateway MT6707 has no A/C or D/C power. I was working and computer cut off. I've removed and reinstalled battery, checked A/C cable and called tech support. Nothing yet has helped resolve the problem. Any help would greatly appreciated.
  • thenelsons Nov 17, 2008
    My MT6707 also died while under AC power. 2 techs say the power source is fine, but problem requires a new motherboard.
  • zhanggr Dec 24, 2008
    I have the same problem
  • Anonymous Jan 05, 2009
    I also have similar problem. My gateway MT6707 was first no ac power, but I still can use my batter until the battery runs out. After that I can not boot anymore and can not charge. Please help me if any one can.
    pnraug
This link shows you step by step with PICTURES and awesome instructions how to completely disassemble and repair keyboard, motherboard, dc power jack and more.
There are links within the instructions for other repairs.
AWESOME site and AWESOME instructions!!!!
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Posted on Jul 21, 2009
    Guru:
  • 1,342 Answers
You can download a service manual HERE from Gateway.
Posted on May 21, 2008
My gateway laptop mt6707 does not recognize it's DVD player
try external drive.if this work,your dvd drive is bad
Dec 17, 2013 | Gateway MT6707 Notebook PC
Gateway MT6707 Laptop...Will not boot. I get an error at start up to "fix problems or Start Windows Normally........I have tried both. Just gets to the screen That shows Gateway and Please...
You need to launch the Last know good configuration to get this fixed.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Dec 19, 2010 | Gateway MT6707 Notebook PC
MT6707 Widescreen Notebook PC (1014360R) PC Notebook: I WANT TO RESTORE A USED GATEWAY MT6707 BACK TO FA...
You can restore the computer back to factory default,to do so, follow the below steps:
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
If the above mentioned steps are not working then you need an RCD to do so. Contact the Gateway support.
May 06, 2010 | Gateway MT6707 Notebook PC
Cannot power on, even when plugin the AC there's no lights (no charging)
Hello
This is a power problem.
First remove try charging your laptop with another power cord to see if it works
If it doesnt,remove the battery from the laptop and plug the laptop directly into power if the laptop comes on,then the battery is faulty and you should get a new one
But if it doesnt then the charging port is no longer working and you should get a repairer to help you change the charging port
Thank you for visiting fixya
Mar 06, 2010 | Gateway MT6707 Notebook PC
My Gateway MT6707's screen makes everything negative.
It sounds like the 'High Contrast' Accesabiliy option in windows has been truned on. This is a setting that a person who has visual imparement might use to be able to see the screen and text better.
To turn this off :
  • Click Start->Control Panel
  • Double Click the 'Accessibility Options 'icon
  • Click on the 'display' tab
  • Remove the check mark from 'Use High Contrast'
  • Click OK
Your screen will return to it's not color/size settings.
Nov 18, 2009 | Gateway MT6707 Notebook PC
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Additional ram on Gateway MT6707
Feom the Gateway site: 2048 MB 533 MHz DDR2 SDRAM (2 × 1024)
Total slots: 2 DDR2 slots | Available slots: 0 DDR2 slots
Maximum memory: 2 GB
Hope this helps.
Dec 23, 2008 | Gateway MT6707 Notebook PC
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
HP nc8000 LAPTOP DISASSEMBLY ETC....
I would try a new power adaptor cord 1st, they go bad alot and I have been on calls to soder the DC power socket many times, when it was simply a power cord problem.
If a new cord does not work the assembly manual can be downloaded from HP at this address:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00803690/c00803690.pdf
Apr 02, 2008 | Computers & Internet
Broken dc jack on gateway 400sd4, need to disassemble
You can download a .pdf service manual from here: http://www.eserviceinfo.com/fulltext.php?search_ft=400sd4 It is a multi-part download so make sure you get all four parts to the manual before you try to open it. (if you need WinRAR to unzip the files you can get a demo at download.com) The service manual has instructions and photos on how to disassemble your laptop. Good Luck, El Duderino
Jun 29, 2006 | Gateway 400SD4 Notebook
Gateway MT6707 Notebook PC Logo
2,571 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
