Question about Epson Stylus CX6400 All-In-One InkJet Printer
Does not print
Has new cartridges. Goes thru "motions" of printing, i.e. carriage or head moves as though it is printing but no print on paper. Communicates with computer. Something blocked or dirty? Can it be cleaned?
  • 1 more comment
  • Segure May 29, 2008
    I have a cx6400 i bought new ink everything seems to be working but when i print the pages comes out blank. I do maintenance check, the nozzle check and head cleaning and i still get blank pages. i spoke with someone at epson and they basically told me that i needed a new printer.If anyone has the same problem or know how to fix this problem please contact me it itsnothing2003@yahoo.com
    Thanks
  • Anonymous Jun 24, 2008
    have replaced all cartridges
  • carllindameg Aug 23, 2008
    I have had the same trouble. I took it in and they told me that it was an old printer (4years old), this is after I bought 4 new cartridges), and it ended up being some main electronic board. About $280.00, plus an addtional $45 extra from what I had already paid them. In other words, a new printer. I really like this printer. I hope that you do not have the same trouble.
  • 96 Answers
The CX series printers use a pigment based ink, and if it dries it frms a semi hard gooy substance on the printer ink input pins.
Sometimes after the insertion of new cartridges (Ensuring the yello tab is removed) and letting them sit overnight (to soften the ink blob) and running several cleaning cycles can unblock the ink "jam". Note: Epsons printer head need ink to cool them when printing (Sort of like oil in a car) so don;t try to print withot having ink flowing to the heads. It can also ruin the print head by overheating.
If all else fails there are several companies that sell inkjet cleaning solution. You may need a couple of cartridges to flush blocked jets but if will most likey work if the print head is still functional.
Otherwise, the technican is correct, you may need to purchase a new printer.
Note; For the future... Never let the ink run out of any cartridge without immediately replacing the cartridge. Never remove an empty cartridge without replacing it immediately.
Posted on Jun 20, 2008
Hi - problem printing as there is no ink on the paper, just cleaned the print head and the purge unit is working as there is fresh ink in the sponge under the parking slot. The printer goes through the...
I think you are a knowledgeable person from your description (thank g-d). It sounds to me as if there is no current getting to the heads heaters therfore she is not firing any ink. This can be a break in the ribbons cables and the fix is to fit a new carriage assy. of course it could be the head itself. Remove and refit the head (no power of course) I reckon if you replaced both then it would fix your problem.
Good luck and thanks for posting your problem.
May 28, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
After cartridge replacement will not print alignment page says print head is obstructed but no evidence for this orange lights at top of control panel flashing along with colour print yellow light power...
try manually moving the carriage and see if it will move freely if it will not move.. there is the possiblity of minute peices of paper jammed under the carriage.
if the carriage moves freely... clean the contacts on the cartridges as well as the contacts on the carriage
Mar 27, 2010 | HP Photosmart C3180 All-In-One InkJet...
Printer goes thru the motions but does not print.have not used in a while. the ink cartridges look clean and the chart shows plenty of ink when i print the allignment page(it's blank twice) the display...
If the printer has been unused for a considerable time the cartridges may have become blocked with dried ink.
Remove the cartridge(s). Take a slightly dampened cotton bud or piece of kitchen paper and carefully wipe the copper coloured surface on the cartridge(s). Then wipe with a dry piece of kitchen paper.
Re-insert the cartridge(s) and perform the print head cleaning function in your printer control panel.
Now try printing.
Mar 26, 2010 | Office Equipment & Supplies
How do you remove printhead from kodak easyshare printer to install new one?
Hello my friend
First make sure that your print head is your problem before replace it
This is how you replace it
  1. If your printer is not powered on, press ON.
  2. Lift the printer access door and wait for the carriage to move to the access position.
  3. Remove any paper that may be loaded in the printer.
  4. Remove both ink cartridges and set them aside.
  5. Unlatch the used printhead.( Lift the button in the center)
  6. Lift the used print head out of the
  7. carriage.
  8. Take out the new print head from its bag
  9. Remove the 3 plastic protective shields.
  10. Place the print-head into the carriage.
  11. Push firmly against the back wall of the print-head until you hear a loud snap
  12. Insert the black ink cartridge into the print-head.
  13. Press down on the ink cartridge until you hear it click.
  14. Do the same for all inks
  15. Close the tray
  16. Lower the front access door and pull the paper tray all the way out.
  17. Insert a stack of 5-10 sheets of plain paper into the paper tray.
  18. For the Calibration:Press Start. Wait 2 to 3 minutes for the calibration sheet to print.
Jan 15, 2010 | Kodak ESP 5 Printer
Handles paper fine but nothing prints. Carriage moves normally as though printing. No ink on paper. Cartridges are partially full.
It sounds as if your print heads are clogged. First try performing a deep cleaning from the Service menu. If this fails to clear your problem you can try to manually clean the heads but you may want to use Q-Tip's and Alcohol to clean the cartidge print head before you go to that expense.
Oct 31, 2009 | Epson Stylus C82 InkJet Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Paper jam?
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
126 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
