Question about EliteGroup 945P-A (945PA11) Motherboard
Display I installed everything on the motherboard including a video card but when I start run and after few minutes it turn off. the other thing is does not display anything at monitor,
    President:
  • 2,351 Answers
Hi quezalte, there are three versions of this board. Please provide which version you have. This can be found on the box or on the board. (v1.1, v2.1 & v3.0)
Did you add thermal grease in-between the CPU heat-sink & fan assembly? Did you clear the cmos/bios page 9, in you're manual. (Do not forget to place the jumper back to Normal as shown in the manual). You're board must have sufficient power to operate. Suggest you're current power supply uses a 24-pin ATA _12v main connector at ATX1 page 10.
(Though the mother board mentions you can use a 20-pin ATX power connector).
(Not suggested).
You also must connect the auxiliary case power supply connector, 4-pin molex to ATX12V page 10 in you're manual.
Lastly, remove & reseat you're video card. Make sure the video cards copper connector's are evenly & completely inserted into the PCIE orange slot. You will not see video display if it is not seated correctly. Some PCIE video cards may also need power. Some may have a connector on them. (If you would have posted the name & model of you're PCIE card I could have advised whether is needs extra power). Lastly, you're power supply should be no less than 450watt. If you add hard drives to all the SATA slots available to you're board. I suggest you use a 550w power supply. If after checking & adjusting all of the above & you still have some problems. Re-post you're problems here.
I will address any & all for you.
Good Luck!
Suggestions & comments welcomed.
Mike
Posted on May 23, 2008
Ms-7108v1
1 long beep dram refresh failed
remove everything
JUST INSTALL MIN. RAM, CPU, CPU FAN, POWER CONNECTION, THAN TURN MACHINE ON, IF OK, CONTINUE INSTALLING I DEVICE AT A TIME UNIT YOU IN COUNTER AN ERROR THAN YOU WILL KNOW WHAT IS WRONG.
now a few things to check video card, ram, cpu fan plugged in right area,
you mite want to reset the cmos, by jumping the connectors for few seconds, then turn machine off, remove jumper, than just install cpu and fan, ram, speaker, keyboard, turn on if ok add video card, turn on , if ok, than install hhd, 1 at a time, than restart system if boots ok than move to next device, keep doing this until you installed everything you want or have to have in the system
Jun 07, 2014 | MSI 848p-neo2-v-848p Neo2-v Intel 848p...
Problem: No display everything running including cpu fan, pci card everything. No error sound. Anyone please help. its a x58 chipset. I also checked that the motherboard getting hanged. like after running...
You will remove the CMOS battery and wait for 5 minutes .
Hope it will solve.
If the problem is same please change or clean the RAM with eraser and install it again.
If the problem is same please ,
http://www.techspot.com/review/129-asus-p6t-deluxe/If the mobo is in warranty should change .If period expire Now you will create a identity mark on BIOS chip and ,you should remove resoiulder the BIOS chip from *********** board .and install it again tightly.
If all the procedure will fail think your mobo should change as new.
Hope this helps.
Jan 10, 2011 | ASUS P6T Deluxe Motherboard
Hey who ever this is im having bad problems with my motherboard or my bios ive tried everything i got ECS C51GM motherboard with the 6100 nvidia video display. icant run any full screen programs cause it...
Its not a bios problem but on insertion of video card your ram got some tampered. Just reinsert the video card and your ram properly and now start your system. It might solve your problem.
May 20, 2010 | ECS C51GM-M Motherboard
Video display problem, on MOBO A780GM-A
Well You Should Check Your Power Settings On The Computer Also I Had The Same Problem Last Year And What Happened Was That The Monitor Was Starting To Burn Out So I Got A New And Now It Works Great. I Also Checked The Monitor Setting Before Getting The New One
Jun 17, 2009 | Computers & Internet
No video on new Gigabyte GA-MA770-DS3 motherboard
There are a couple things that you need to look at. The first is your power supply. I've had computers seeming to run fine with no video. Turned out to be bad power supplies.
Does your video card require a power connection? Many high-end video cards need an external power connection. If the card has a power connection, use it.
Have you gone in and checked the cmos settings? What does it say (if anything) for the default video?
Now remove all connections to drives (hard drive and CD and try for video. Try it.
Next, if possible, swap out memory.
After you've tried everything (including maybe burning incense), time to try a new motherboard.
May 27, 2009 | Gigabyte Computers & Internet
Laggy display after a few minutes play
lot of the game now a days require a pretty big video card. A 5200 is outdated and i know u cant upgrade your laptop. The best solution to this is increase the amount of RAM in your laptop to the max. When you run games lower the video settings to low or medium. Another thing that can help is running msconfig in the RUN box and turning off lot of apps that run in background
May 19, 2009 | Nvidia Geforce FX 5200 Graphic Card
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
SuperMicro H8DCE-O R Motherboard no video
did you plug up toe power to the video card, the problem seems to be that the video card is getting no power, if the power is hooked up properly to the video card, the your power supply is probably not powerful enough.
Dec 04, 2008 | SuperMicro H8DCE-O R Motherboard
No Display on screen.
If available, try using a different video card to see if it will POST. The only other thing I can think it might be is that the processor isn't seated correctly, or that it is seated correctly but you have too little, or too much thermal compound on the CPU.
Sep 15, 2006 | AOpen AX45-V (91.88I10.004) Motherboard
EliteGroup 945P-A (945PA11) Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
