Question about Hitachi 53UDX10B 53" Rear Projection Television
Re: convergence i have the same problem. The green is out of line and i have tried to reset it by unplugging the tv and also the pressing the reset on the convergence button. NOTHING HAPPENED ! Everything was fine unitl my son hooked up the Wii to the TV and then several days later the problem occured. Do you think it was the Wii ? Also what can I do about it?
  • Hitachi Master
  • 8,617 Answers
You will need to change both convergence ICs number STK392-120 uou can get replacements at the following link and they provide free instalation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
I doubt that the wii caused it, as this is a common occurance in all rear projection TVs.
Posted on May 21, 2008
I have multiple colors on the screen of my 530hd pioneer elite TV when it warms up. When I try to adjust the convergence I am unable to move the red line far enough to converge on the blue or green line.
The convergence of your tv is defective try to replace it. You will find the convergence chip inside your tv, try to open the back cover of your tv but be sure to unplug the tv first. Try to look the large aluminum plate it is the heat sink, your convergence chip is attached to that heat sink it has a marking of stk-*** followed by a number you should remove it from the pcb using a soldering iron, and soldering pump but be very careful you might damage the pcb and may caused another fault to your unit. Or you can contact a service technician to save you from stress. Good day and best regards.
Jul 19, 2011 | Pioneer PRO-530HD 53" Rear Projection...
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba 41h81 green convergence problem
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
LINES ACROSS TV
Good Day, YOU ALL;
Try this: 1. E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970"
2. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
Also you may poor solder connections on the vertical output IC or on the CONVERGENCE IC's.
Hope this helped, good luck, big IRISH.
Jun 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Colored Lines at the top of the picture
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 19, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Convergence
Loss of power supply voltage to run convergence circuit.verify w/service literature.Hands-on technical help needed.
Aug 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
Hitachi 53UDX10B 53" Rear Projection Television Logo
22 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
