Question about E-Machines Computers & Internet
When turned on my computer has a drop down box that says HTTP500 Internal Server Errow
    President:
  • 2,712 Answers
You generally only get this error when trying to view a dynamic web page. This is a generic error. If you receive this error message when trying to run a dynamic web page such as ASP, PHP, etc. and you are getting not getting a detailed error message then you are more likely seeing a generic error message generated by Internet Explorer.
To get a detailed error message to help with debugging your dynamic web page you need to Turn Off Friendly HTTP Error messages in Internet Explorer (IE).
For more information and a step by step guide to do this, please see Turn Off Friendly HTTP Error Messages in IE.
If, however, you are getting this message elsewhere, please post back as to where and when you are getting this error.
Posted on May 21, 2008
    Master:
  • 555 Answers
What is the model of your eMachine computer?
  • Matt Jurach
    Matt Jurach May 21, 2008
    HTTP 500 errors are not that bad.
    It's not an error on your own machine. It's an error on a website that your machine has connected to.
    Quitting Internet Explorer and reopening Internet Explorer should clear the error.
    Shutting down your computer and restarting it should also clear the error. Make sure that you are shutting down the computer completely, not just making it "sleep" on standby, or "hibernate."
How to set time and date?
Automatically Set Computer Clock
It's really upsetting when a once reliable computer starts to lose time.
Most of us rely on our computer clock to keep us aware of the time spent on the Internet or working on a project on the computer.
So, time is important.
Here is a way to configure the computer so that it automatically synchronizes the time with a time server.
Note: You have to be online for the synchronization to take place.
The first step is to open the date and time dialog box located on the task bar on your computer. Should be on the lower right side of the task bar.
Right click or Double click time to open the dialog box.
The date and time box should open on the desk top.
Now click the Internet time tab.
Check the box that says automatically synchronize with an Internet time server.
Then you will see a list of servers.
Select a server from the drop down list.
Check apply and close the box.
Now every time you go on the Internet Windows will automatically set the computer clock to the right time.
Now, there is no need to worry about adjusting the computer clock again!
Jul 26, 2013 | HEWLETT-PACKARD HP 4500 All In One Printer...
How to set time
It's really upsetting when a once reliable computer starts to lose time. Most of us rely on our computer clock to keep us aware of the time spent on the Internet or working on a project on the computer. So, time is important. Here is a way to configure the computer so that it automatically synchronizes the time with a time server. Note: You have to be online for the synchronization to take place.
The first step is to open the date and time dialog box located on the task bar on your computer. Should be on the lower right side of the task bar. Double click time to open the dialog box. The date and time box should open on the desk top. Now click the Internet time tab. Check the box that says automatically synchronize with an Internet time server. Then you will see a list of servers. Select a server from the drop down list. Check apply and close the box. Now every time you go on the Internet Windows will automatically set the computer clock to the right time. Now, there is no need to worry about adjusting the computer clock again!
Feb 09, 2013 | Computers & Internet
Call display
Double click time or right click to open the dialog box.
Hope this helps.
Nov 18, 2012 | Computers & Internet
Its seems the internal power supply fails and burned out.... some are saying it is common issue of all d link switching hub? is it possible to use an replacment power supply?..
its not a common issue it the problem from ur building earthing plz chek voltages for this u get i.e, neutal face and earth
in earthing u have to get only below 3 volts in case u get more than that its sure ur problem that ur facing is with voltage variation
the common issues of this switching is
I administer a small network for a cab company, and have lately been battling an internal connectivity problem for the last several days. It seems that 2 of the 5 computers on the LAN intermittently "drop" connection without losing their IP addresses. If I disable the network connection on the "dropped" machine, and then immediately re-enable it, it seems to work for anywhere from 5 minutes to a couple of hours, then "drops" again. All LAN IP addresses are configured manually. I've posted an image of the network map at http://www.geekcavecreations.com/images/network_map.gif to illustrate how the LAN is arranged.
The local network has 2 computers that connect to the internet through the DSL router, one for ICS, and the other has an external web server (neither one has connectivity problems).
One computer on the LAN has an internal web server that handles our dispatch program. All computers on the network need to be able to access this box.
The dispatch client has to access the dispatch server, but can't have internet access. It's blocked from the internet through the simple expedient of not having an external DNS server assignment.
Now, for the meat of the problem. I've checked and re-checked the configurations for both the dispatch server and the dispatch client, and find no problems. Both have the most recent drivers for the network cards, and both have new cables. I've swapped out a known good hub for the LAN, and have made sure that there are no mis-configured hosts files. As outlined previously, disabling and enabling the NIC on the offending machine will restore connectivity for a while. I've checked each machine for an overheating problem, just in case, and find no trouble there. All machines are running XP Pro.
I can't shake the feeling that I'm missing something basic and simple, but I'm at a loss as to what that might be. Any suggestions?
Mar 28, 2011 | D-Link (DMC-1001) Power Supply
How do I get the at sign on this turkish keyboard
Should be shift and key 2
how to add the Turkish keyboard to your computer running Windows and how to utilize this new keyboard layout.
There are six letters in the Turkish alphabet that are not in the English alphabet, namely '?, ?, ?, ?, ?, ?'.
For writing these letters without going into the hassle of using the alt codes or copy-pasting from some other location, you can simply add the Turkish keyboard layout to your Windows computer system.
Using the same keyboard, the layout will change a little to let you allow to type the Turkish letters.
Windows XP and Windows 2000 Users
Go to start/control panel
Here, if you see Date, Time, Language, and Regional Optionsdouble click on it and continue with Add other languages.
Select the Languages tab in the window that will show and click on the button that says Details...In the Settings tab of the window that comes now, click the button that says Add... In the drop-down box titled Input Language, select Turkish. In the drop-down box below that, named Keyboard layout/IME, select Turkish Q and click OK. Click OK until all the windows we opened are gone.
In the control panel, if you don't see Date, Time, Language, and Regional Optionsicon but there is an icon titled Regional and Language Options, double click that. Select the Languages tab in the window that will show and click on the button that says Details...In the Settings tab of the window that comes now, click the button that says Add... In the drop-down box titled Input Language, select Turkish. In the drop-down box below that, named Keyboard layout/IME, select Turkish Q and click OK. Click OK until all the windows we opened are gone.
These instructions apply for the following versions of windows:
• Microsoft Windows Server 2003, Enterprise Edition
• Microsoft Windows Server 2003, Standard Edition
• Microsoft Windows XP Home Edition
• Microsoft Windows XP Professional Edition
• Microsoft Windows Small Business Server 2003 Standard Edition
• Microsoft Windows Small Business Server 2003 Premium Edition
• Microsoft Windows 2000 Professional Edition
• Microsoft Windows 2000 Server
Windows 98, and Windows Me Users
Go to Start/Settings/Control Panel/Keyboard
Click on the Language tab here, and then click the button Add.
Now, from the list of languages you see, select Turkish. Say OK until all the windows we opened are gone.
Nov 18, 2010 | A4tech X-Slim KL7MU
ProLiant DL160 G6 Server, Part Number 593352-B21, Serial Number USE029N5Z2. The system fails to power on. The power supply has the LED light green. The start button does not turn amber. Do not...
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Aug 04, 2010 | HP ProLiant DL160 G6 Server - 1 x Xeon...
CAN NOT PRINT LIGHTSCRIBE LABLE
Your problem is posted under the LG CRD 8521B CD-ROM drive category. That model of CD drive isn't a LightScribe drive, so it can't print LightScribe labels.
Dec 21, 2009 | LG CRD 8521B Internal 52x CD-ROM Drive
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Internal Server problem Internal server errow 500
delete temp file s from the desktop and run disk cleanup
May 21, 2008 | Computers & Internet
Computers & Internet Logo
270 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
