Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
My access point have problem, when i connected to the network, just a minute thats disconnect and the signal i can read in my computer, how to repair this?
2 Suggested Answers
SOURCE:
  • 47 Answers
SOURCE: Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Posted on Sep 08, 2007
Disconnecting in a few minutes
Change your position , that might help the signal to be better, wireless signal gets obstructed
Nov 23, 2013 | D-Link Dap-2310 Wireless Access Point
Disconnecting in afew minutes
Nov 23, 2013 | D-Link Air Premier DAP-2360 Wireless...
Satellite p35 will not go to wireless
Might not have a wireless card installed ??
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop.
However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings."
This will give you options for modifying how you connect to the Internet.
Select "Connect to a Network" or "Show Network Status and Tasks."
Both selections will show you whether you are disconnected from the wireless network.
Select "Manage Network Connections."
This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection.
Engage the wireless connection.
Turn your wireless switch to "On," then right-click on the wireless network connection.
Select "Connect/Disconnect."
Wait for the IP address acquisition.
It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address.
When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength.
Launch your favorite browser to access the Internet using the wireless connection.
http://forums.computers.toshiba-europe.com/forums/thread.jspa?threadID=18365
Aug 25, 2013 | Computers & Internet
How to load Integrated Wireless LAN on my toshiba satellite a45-s1202
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop. However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings." This will give you options for modifying how you connect to the Internet. Select "Connect to a Network" or "Show Network Status and Tasks." Both selections will show you whether you are disconnected from the wireless network. Select "Manage Network Connections." This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection. Engage the wireless connection. Turn your wireless switch to "On," then right-click on the wireless network connection. Select "Connect/Disconnect." Wait for the IP address acquisition. It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address. When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength. Launch your favorite browser to access the Internet using the wireless connection.
Feb 03, 2013 | Toshiba Satellite A45-S1202 Notebook
Slow connection low signal
If a wireless network has low signal strength, the transfer of information across the network could be slow or you might not be able to access certain parts of the network. Here are solutions to some common problems with low wireless signal strength: Your computer is too far from the wireless router or access point. Move your computer closer to the router or access point. If your computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer. If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than the built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna. The wireless router or access point is turned off or isn't working properly. There are two things to try: o Make sure the router or access point is turned on and that the wireless signal light is illuminated. o Reset the router or access point by turning it off, waiting at least 10 seconds, and then turning it back on. If you don't own the access point or don't manage the network, contact the network administrator. There is interference from other devices. If you have 802.11b or 802.11g network hardware, it uses the 2.4 gigahertz (GHz) frequency. Other devices that use this frequency include microwave ovens and cordless phones. If you have 802.11a network hardware, it uses the 5 GHz frequency. Some cordless phones also use this frequency. These devices can cause interference between your computer and the network. There are two things you can try in this situation: o If any devices like these are near your computer, turn them off temporarily or move them farther away. o Change the router or access point settings to use a different wireless channel, or set the channel to be selected automatically if it's set to a fixed channel number. Sometimes one wireless channel is clearer than others. In the United States and Canada, you can use channels 1, 6, and 11. Check the information that came with your access point or router for instructions about setting the wireless signal channel. The network you're looking for is set to not broadcast its network name (SSID). Wireless routers and access points can be set up so that they don't broadcast the network name. In this case, you can't detect that the network is in range (in order to connect to it) unless you've previously connected to the network or you manually connect to the network using the service set identifier (SSID). To connect to a network that's not broadcasting, follow these steps: 1. Open Connect to a Network by clicking the network icon ( or ) in the notification area. 2. Click Unnamed Network, and then type the network information. The network will be added to your list of networks and will be available to connect to in the future when your computer is in range of the network.
Dec 27, 2012 | Computers & Internet
Engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
Wireless Network Connection constantly reading low/vlow/no signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 04, 2010 | Computers & Internet
My wireless network connection status in connected Speed is11.0 and my signal strength is good, but I cannot connect to the internet connection godd but internet explorer cannot display the webpage
You are getting local access only.
Right click on the icon in the system tray and click repair....
If it still happens you need to connect to a different network..this usually happens if you are connecting to an unsecured network (I assume yours).
Alternative: Unplug the network adapter. Turn off the computer. Wait approx 2 minutes.
Power on computer with net adapter connected....
Dec 18, 2009 | Sony Computers & Internet
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Intel 2915AB Connection problem
Intermittent disconnection issues on a radio/wireless network will generally be caused by interferance (speakers, power board fully loaded, High wattage Lamp (flourescent bulbs usually) all parked too close to the wireless router, access point or network card. or possibly due to interuption of the active signal possibly because the distance of the router and network card/access point is just on the edge of the best signal limit and disruption occurs when someone or something gets up and moves itself inbetween the two service points)I resolved my disconnection issues by purchasing a wireless Kite for the access point and router, which will intensify the radio signal and bring the access points within closer range of each other, friends of mine have resolved intermittent signal issues by making a thin tube of rolled tinfoil about 30cm long slipped over each aerial affected by the intermittent signal disconnection. Also verify the "line of sight and non line of sight" signal distance limits for your radio equipment as the signal distance will decrease depending on the age of your wireless equipment, most equipment is in the 30Ft non line of sight- 100Ft line of sight arena out of the box but you can expect to half this figure after 3 - 5 years of continued use. Basically three options Interferance, Interupption or age only distance testing will verify this accurately IE: bring the router and access point withing 1Ft of each other and start walking away still holding the access point, whilst a user monitors the radio network condition.
Aug 04, 2006 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
21 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
