Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Heavy Duty Super Capacity Plus
For a couple of months now my washer would stop for long periods of time after the wash cycle was over. When it started back up it would make this loud cranking noice or a grinding noise and would begin the rinse cycle. Then the spin cycle would begin but the washer would not spin and the clothes remaind very wet. Along with that the fabric softner would not dispense. What I had been doing was turning it of and starting it back up again to begin at the spin cycle and then it would spin and dispense the fabric softner. Today however when I when to turn it of to start a new cycle this poping noise occured and I saw a light purple/white light from the top rear of the washer. After this my washer would no longer turn on. I am now left with a small load of clothes with water in the washer! PLEASE advise if fixable on our own or should we call it in or should we just buy a new one? Thanks a Million for the help!!!!
  • Mrs Diana Aug 18, 2008
    I have a Kenmore 90 series 20908 top load and the spin cycle isn't working; it'll wash but it will not dump out any water nor will it go into spin cycle. Can you help. I believe it has something to do with the lid and the switch that it activates. My husband pushed the switch in manually however we don't want to have to do this everytime. If we have to can that switch be replaced and if so .. for how much and how long to get the part? thank you
    Diana
  • robert samples May 11, 2010
    may be send me the complete model number off the washer serial plate off the washer and let me see which company built it for kenmore
    Genius:
  • 1,028 Answers
That is a whirpool source washer suspect wire underneath console may be where connector from wall plug connects underneath ckd all wires around timer possible power loss has been problem from the first but try to some action going again first good luck
Posted on May 22, 2008
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
177 people viewed this question
Sal De
fordexpert
Robert Rankin
