Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Hitachi model 57F500A
Television is 5 years old. The picture is dominated by red and blue there are no flesh tones or greens
  • Anonymous Dec 16, 2008
    i need a replacement remote but do not know part #
  • Anonymous Dec 22, 2008
    I also have the color issue, my TV color is mostly red and blue, my green is starting to fade out, and the color is getting darker, flesh tones are looking more orange/red than flesh color.
    What do you think it will cost me to get my CRT replaced?
  • Hitachi Master
  • 5,568 Answers
Your unit uses a Cathode Ray Tube (CRT) for each color.
Since you didn't say that it was a gradual change, I suspect the CRT filament has failed open rather than a slow death of internal emissions.
Considering the very high level of light asked of these CRTs, I am amazed they last as long as they do.
The replacement and almost certain necessity of initial alignment and color balance, this is beyond DIY possibility and is likely going to be fairly expensive.
After 5 years of use, the other CRTs are somewhat (if not a lot) degraded so don't be surprised when a tech advises replacing them all and I think it may not be a whole lot less expensive than replacing the set although looking at the specs for that set indicates it is not obsolete by any means.
Posted on May 21, 2008
Blue streak and no red on Hitachi 50V500A rear projection TV
Check a second source such as a dvd player or game system using different cables. If the same issue happens then the tv will need repair. However if the issue is not the same it is either cables or the original source.
May 06, 2010 | Hitachi 60V500 60" Rear Projection...
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
57F500A, powered light on with no sound/picture, ticking noise
Over the years of servicing these sets and others for Convergence issues, I have on several times gotten defective Convergence ICs. In your case where a Resistor is now open, (Probably a 1.5 ohm 1/2 watt), I would suspect you had gotten a hold of a defective IC. I would replace them both again. Make sure to use Heat Sink Compound between the ICs and Heat Sink.(Just a thin coating on the metal area) You can get the heat sink compound from Radio Shack. They should also have the Resistor you need.
Good luck,
Skyassoc
Jul 23, 2009 | Hitachi 57F500 57" Rear Projection...
Power but no picture
I doubt it is the picture tube...there are three of them.. a red. a green, and a blue. Would suspect something on the power/deflection board
Jul 05, 2009 | Hitachi 57F500 57" Rear Projection...
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
HITACHI TV MODEL 57F500A
My hitachi 57f500a wont turn on i pulled the back off and there are only one green light on and the relay keeps clicking when the relay clicks another green light flickers and the red one come on and goes off.
May 04, 2008 | Hitachi 57F500 57" Rear Projection...
Flesh tones and red colors
any hue adjustments usally relly cheap tv u got also hard to get good colers from it the lg one is nice i like samsung and sharp
go throw azll colers cheak dvd cables
Jan 06, 2008 | Insignia IS-LCDTV32 32 in. Television
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
355 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
