Question about Dell 924 All-in-One InkJet Printer
Printer at first when I put the cartridge in it just said it was empty now i put in a new one, now the printer screen stays blank and the printer doesn't even want to turn off. It won't print,scan or take copy. Any type of solution????????
  • 41 Answers
Remove both the cartridges from the printer and unplug the power adapter from the back panel of the printer , wait for 1 minute and plug it back , install the cartridges again , and try to copy a document.
lemme know if this helps !!!!
Posted on May 22, 2008
Why my printer Hp Photosmart workin good but not printing.Only blank page.?
I would suspect a clogged or empty ink cartridge. Put the bottom of the cartridge in a small cut of very hot water, near boiling for about 30 seconds, it will clear the clog if that is the problem.
Aug 12, 2016 | HP PhotoSmart Office Equipment & Supplies
Magicolor 2400W toner cartridges not empty
Have you tried taking the toner cartridge out of the printer and shaking it up a bit? Just make sure you do it outside or over a trash can. Shake it side to side.
Sometimes the toner bunches up and you can get some more life out of it by shaking it up.
Hope this helps
Mar 24, 2008 | Minolta magicolor 2400W Laser Printer
Toner light stays on after I changed cartridge
These are defects of Brother cartridges, even you put a new cartridge the toner empty still not reset. What we are doing is re-positioning the toner end cam on the side of the cartridge. You have to be knowledgeable with the machine to to that.
Apr 14, 2013 | Brother HL-2170W Laser Printer
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Thougth printer cartridge was empty, printing blank, put new cartridge in and still blank pages. What is my issue?
Most toner cartridges have a pull tab on them to open the flow of the toner. Maybe you didn't pull this tab. Also most machines want you to perform an alignment process for the new cartridge and if you haven't done this it will sometimes cause the printr not to print correctly.
The old printer cartridge may have been so low on ink that it did not print properly.
Sep 21, 2010 | Dell P1500 Laser Printer
I use to refill my brother dcp-130c printer cartridge.but now it shows black cartridge empty also colour cartridges near empty..after I purchace new black cartridge also same messahe appears..pls help me...
the electronic on your printer, the one that detects the black cartridge might be dirty, try cleaning it with some tissue. if that doesn't work, try removing the installation of your printer and then install it back again. if you have any other black cartridge, put it in the printer and try printing. If a page comes out, even if it's blank, then it's the black cartridge that has an issue. try that and let me know.
Mar 03, 2010 | Brother DCP 130C All-In-One InkJet Printer
My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Feb 13, 2008 | Lexmark Z816 Color Inkjet Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Red light
It could be a faulty printer cartridge(it happens). One way to check for this is put in your old cartridge(even if its empty!). If the printer goes to a ready state with your old cartridge, then the new cartridge you replaced might be the problem! if you are refilling cartridges, check out this site let me know how this turns out regards, babb
May 10, 2007 | Epson Stylus Photo 1280 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
46 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
