1999 Dodge Dakota Logo
Posted on Sep 24, 2010
What is proper headlight adjustment - 1999 Dodge Dakota
Anonymous
Level 1:
  • Contributor 613 Answers
  • Posted on Sep 24, 2010
Anonymous
Contributor
Level 1:
Answers
613
Questions
Helped
167963
Points
35
You pull up to a wall and the headlights should be at 3 foot high and the drivers head light should be turned in 4 inches towards passenger headlight
How do I adjust my Headlights on a 2018 Mitsubishi ASX
I'd suggest you take them to a shop where they have the proper headlight alignment tooling. You won't get it right without proper equipment. The state used to inspect cars for proper headlight alignment, but I don't know that they do that any more.
2answers
How do I adjust headlights on 2007 Lincoln Towncar
Should be an adjuster screw on the back of the headlight
1helpful
Where, exactly, are the headlight adjusters for the drivers side headlights?
What is the proper adjustment/
Head light adjusters are part of the head light assembly and yes high and low beam are adjusted as one unit normally. Proper adjustment is done on a machine, at an equipped facility.
Headlight adjustment
Take it to mechanic with proper equipment to set them
2helpful
How do i adjust the head lights on a 1997 grand marquis
AIMING THE HEADLIGHTS
On 1989-91 vehicles, the headlights can be aimed using the adjusting screws located above and to the side of the headlight bulbs. A rough adjustment can be made while shining the headlights on a wall or on the rear of another vehicle, but headlight adjustment should really be made using proper headlight aiming equipment.
On 1992-98 vehicles, the aerodynamically styled headlights necessitate the use of headlight aiming kit 107-00003 or equivalent. The adjustable aimer adapters provided in the kit must be used to aim the headlights. Adjustment aimer adapter positions are moulded into the bottom edge of the headlight lens. Set and lock the adjustable adapters, attach each adapter to its mechanical aimer and aim the headlights according to the instructions in the kit.
Headlight aim adjustment should be made with the fuel tank approximately half full, the vehicle unloaded and the trunk empty, except for the spare tire and jacking equipment. Make sure all tires are inflated to the proper pressure.
The headlights must be properly aimed to provide the best, safest road illumination. The lights should be checked for proper aim and adjusted as necessary. Certain state and local authorities have requirements for headlight aiming; these should be checked before adjustment is made.
CAUTION About once a year, when the headlights are replaced or any time front end work is performed on your vehicle, the headlight should be accurately aimed by a reputable repair shop using the proper equipment. Headlights not properly aimed can make it virtually impossible to see and may blind other drivers on the road, possibly causing an accident. Note that the following procedure is a temporary fix, until you can take your vehicle to a repair shop for a proper adjustment.
Headlight adjustment may be temporarily made using a wall, as described below, or on the rear of another vehicle. When adjusted, the lights should not glare in oncoming car or truck windshields, nor should they illuminate the passenger compartment of vehicles driving in front of you. These adjustments are rough and should always be fine-tuned by a repair shop which is equipped with headlight aiming tools. Improper adjustments may be both dangerous and illegal.
For most of the vehicles covered by this guide, horizontal and vertical aiming of each sealed beam unit is provided by two adjusting screws which move the retaining ring and adjusting plate against the tension of a coil spring. There is no adjustment for focus; this is done during headlight manufacturing.
Because the composite headlight assembly is bolted into position, no adjustment should be necessary or possible. Some applications, however, may be bolted to an adjuster plate or may be retained by adjusting screws. If so, follow this procedure when adjusting the lights, BUT always have the adjustment checked by a reputable shop.
Before removing the headlight bulb or disturbing the headlamp in any way, note the current settings in order to ease headlight adjustment upon reassembly. If the high or low beam setting of the old lamp still works, this can be done using the wall of a garage or a building:
  1. Park the vehicle on a level surface, with the fuel tank about 1 / 2 full and with the vehicle empty of all extra cargo (unless normally carried). The vehicle should be facing a wall which is no less than 6 feet (1.8m) high and 12 feet (3.7m) wide. The front of the vehicle should be about 25 feet from the wall.
See Figure 6
Fig. 6: Example of headlight adjustment screw location for composite headlamps
  1. If aiming is to be performed outdoors, it is advisable to wait until dusk in order to properly see the headlight beams on the wall. If done in a garage, darken the area around the wall as much as possible by closing shades or hanging cloth over the windows.
  2. Turn the headlights ON and mark the wall at the center of each light's low beam, then switch on the brights and mark the center of each light's high beam. A short length of masking tape which is visible from the front of the vehicle may be used. Although marking all four positions is advisable, marking one position from each light should be sufficient.
See Figures 7 and 8
Fig. 7: Low-beam headlight pattern alignment
Fig. 8: High-beam headlight pattern alignment
  1. If neither beam on one side is working, and if another like-sized vehicle is available, park the second one in the exact spot where the vehicle was and mark the beams using the same-side light. Then switch the vehicles so the one to be aimed is back in the original spot. It must be parked no closer to or farther away from the wall than the second vehicle.
  2. Perform any necessary repairs, but make sure the vehicle is not moved, or is returned to the exact spot from which the lights were marked. Turn the headlights ON and adjust the beams to match the marks on the wall.
  3. Have the headlight adjustment checked as soon as possible by a reputable repair shop.
Hope thats helped (remember rated this) Good luck.
7helpful
2answers
How are the headlight adjusted for aim
there is one screw on top and one on the side of each light for adjustments
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
3helpful
How do you align or focus headlights beams that are to
Fig. : Location of the aiming screws on most vehicles with sealed beam headlights
Fig. : Dual headlight adjustment screw locations-one side shown here (other side should be mirror image)
Fig. : Example of headlight adjustment screw location for composite headlamps
Fig. : Low-beam headlight pattern alignment
Fig. : High-beam headlight pattern alignment
Hope helped with this information. Good luck (remember rated this help).
3helpful
How do you adjust the headlights on a 1998 ford F250 pickup
Park the vehicle on a level surface, with the fuel tank about 1 / 2 full and with the vehicle empty of all extra cargo (unless normally carried). The vehicle should be facing a wall which is no less than 6 feet (1.8m) high and 12 feet (3.7m) wide. The front of the vehicle should be about 25 feet from the wall. 5374ba7.jpg
Fig. Example of headlight adjustment screw location for composite headlamps
If aiming is to be performed outdoors, it is advisable to wait until dusk in order to properly see the headlight beams on the wall. If done in a garage, darken the area around the wall as much as possible by closing shades or hanging cloth over the windows. Turn the headlights ON and mark the wall at the center of each light's low beam, then switch on the brights and mark the center of each light's high beam. A short length of masking tape which is visible from the front of the vehicle may be used. Although marking all four positions is advisable, marking one position from each light should be sufficient. 30c25df.jpg
Fig. Low-beam headlight pattern alignment
Fig. High-beam headlight pattern alignment
If neither beam on one side is working, and if another like-sized vehicle is available, park the second one in the exact spot where the vehicle was and mark the beams using the same-side light. Then switch the vehicles so the one to be aimed is back in the original spot. It must be parked no closer to or farther away from the wall than the second vehicle. Perform any necessary repairs, but make sure the vehicle is not moved, or is returned to the exact spot from which the lights were marked. Turn the headlights ON and adjust the beams to match the marks on the wall. Have the headlight adjustment checked as soon as possible by a reputable repair shop.
Hope helped with this (remember rated this help) Good luck.
1helpful
Headlights need to be aimed properly
of course you can...try fixing it during night time in a place that is dark. in a street that is no traffic is the best place. pop the hood and look behind the headlight assembly. you will see two long screws that can be adjusted by tightening or loosening the screw for up and down adjustments and left and right adjustments
I had this problem. The plastic grommet that the headlight fit into was cracked. I got a headlight assembly from CertiFit (cheaper than dealer.) Or try a junkyard.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
