Question about Kenmore 62602 Electric Dryer
Kenmore 90 Series Electric Dryer will not run
Worked fine last use. Will not start now. Checked all of the obvious fuse/breaker, door shut, turned on, etc.
  • 2 more comments
  • bj43 May 23, 2008
    door switch is broken. how do I open the cabinet?
  • Anonymous Jul 22, 2008
    yes i also have problem when i push start button it clicks then nothing if i turn to off i hear a double click then push start buttton then it just clicks again
  • reed2donna Aug 16, 2008
    Dryer stopped working. Checked breaker, Ok. Took back panel off. Timer on main switch is clearing moving ( ticking). A sound is made when the start button is pushed, but nothing happens. At one time, when I left the switch on Wrinkle Guard, it just started running on its own. So, its somewhat intermittent. I hear clicking as I turn the main switch 360 deg, through all it's settings. It just doesn't seem to be getting power to the turning drum. Any suggestions/??? Stock # on back is 65914.
  • trguillo Sep 20, 2008
    My dryer worked fine last use. Now it will not turn on. Can still hear timer ticking. Breaker is not tripped.
  • 868 Answers
Listen very closely to the dryer right as your pushing start.Is there any sound at all.Listen very closely because its critical on making the diagnosis.
Posted on May 22, 2008
I push my starter and hear the motor but will not complete the start. dont want to burn the motor out. Should I check the belt or thermal fuse unit?
Posted on Feb 23, 2010
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jun 30, 2011 | Kenmore Dryers
My Kenmore 90 series electric dryer not running ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
Oct 27, 2009 | Kenmore 64902 Electric Dryer
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore electric dryer series 90 model 66904691 will not start. Dryed a load of clothes went to start again will not do anything , checked fuse box, fuse not blown what could be the problem
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Aug 23, 2008 | Kenmore Dryers
Kenmore 62602 Electric Dryer Logo
929 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
