Question about Hotpoint NLL113EYWO Electric Dryer
HotPoint Dryer where do I locate the heating eliment in my dryer and do I have to take the drum out. The dryer runs but won't heat
  • 550 Answers
Heating elements in dryers are almost the least likely cause of heating failure, they are solid and have no moving parts, more likely is the thermal cutout, an over temperature fuse that mounts on the element housing
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219235 part 1233 is the part, and clicking diagram 3 on the left shows how to get to it
can be tested with any multimeter, zero resistance is good, infinity resistance - burned out
Posted on May 21, 2008
Hotpoint dryer wont heat
bad heating eliment
Nov 16, 2013 | Dryers
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Oct 27, 2012 | Hotpoint Dryers
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Dryer won't heat up, therefore won't dry clothes. good air flow from vent. not sure what part may need.
If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
IMPORTANT: Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Begin by verifying the source voltage at the receptacle and service breaker, and verify your power cord.
The reason a dryer may still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
NOTE: If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If you have questions, require additional assistance, please post back and let me know. I hope this helps you.
Aug 17, 2011 | KitchenAid KEYS700LQ Electric Dryer
Wirlpool dryer heating eliment keeps braking
Sounds like you use dryer sheets. If you do, try cleaning your lint screen with vinegar. Dryer sheets leave a film on the screen that the dryer eventually can't breathe through, the dryer overheats and burns up the elements.
May 26, 2009 | Whirlpool LER5636P Electric Dryer
Hotpoint electric dryer model nvl333eb4cc not dryer clothes. where and how to check for the heating elements or any component that might be at fault
1. Reset a circuit breaker
2. To check the component you have to lift the top of the dryer.
3. all heating component located on the back of the drum.
4. The problem could be one of the safety thermostats or heating element.
5. To replace a heating element is to complicated if you do not have experience.
6. let me know if you going to do this
Nov 29, 2008 | Hotpoint Dryers
Where do I find the heating element in my hotpoint dryer
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Sep 12, 2008 | Hotpoint NLL113EYWO Electric Dryer
Heating elements will not heat
If you dryer is running but not heating then you may have one of the following problems.
Make sure you have 220-240 volts to the machine. If one leg of you breaker has kicked you will only be getting 110 volts this will cause the dryer to run and not heat. Simply kick the breaker off and back on to fix.
If you have enough voltage then you may have a bad thermostat, thermostats or heating element. I recommend you take your heating element off and look for broken lines.check continuity if possible. If the heater is good then go to the thermostats. Check continuity. Replace if you find a bad one. Good luck and I hope this helped. mca0824@aol.com
Apr 29, 2008 | Hotpoint NLL113EYWO Electric Dryer
Drum in dryer not turning but still heat
Sounds like you need a new dryer belt, call sears for new belt. Install the new belt around the drum and to the motor located near the bottom of the machine.
Oct 19, 2006 | Hotpoint TDC32 Electric Dryer
Hotpoint NLL113EYWO Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
