Question about Frigidaire ATF6000ES Front Load Washer
Replacement grease for drum shaft seal
I removed my drum to extract a "underwire" that departed a garment and got stuck in the spokes behind the drum. In the course of this the grease sealing the shaft became contaminated with grit (corrosion on the spokes) and was wiped off.
What should I use for replacement grease on the shaft at the seal? Frigidaire doesn't appear to list this as a part. I know it needs to be both water resistant and stay put well enough to not soil clothing. I'm considering trying non-silicone plumbers grease if I can't get anything else.
Regards, ks
  • Anonymous Mar 13, 2014
    Found some grease in drum comeing out of agitator shaft
  • 868 Answers
You really dont have to use any at all unless you have removed all of it.Remember 99% of these bearings are self lubricating.
Posted on May 22, 2008
I have a Whirlpool Cabrio top load washer. Am I suppose to grease the drive shaft before I put it back together?
The grease would end up on your garments.. replace the drive shaft and bearings, then STOP USING LIQUID DETERGENT. use only HE powder!!!
Whirlpool Washing Machine Tub Seal and Bearing Kit W10435302
Apr 12, 2017 | Whirlpool Washing Machines
My washer is making a card stuck in bicycle spoke sound during rinse/spin cycle
Something has probably got behind the drum. Usual suspects are broken underwires from bras and hair clips or pins.
Spin it by hand when empty, both ways and see if you can figure out where it is at. Check the filter and the flexible rubber hoses from the drum drain point to the filter and the filter to the pump. Give those hoses a squeeze and see if you can feel anything in them. I have found bits of underwire, coins and small metal items. They are removable with a bit of effort, but be prepared for water spillage. Take a photo before you remove anything so you can see how it all fits back together.
Feb 03, 2016 | Maytag Centennial MVWC300VW 3.2 Cu. Ft....
Want to replace e brake on 1996 450 drum on drive line behind trans once the drum is removed do you have to remove the hub to install the brake if yes how
yes, remove the drive shaft and brake drum then remove the big nut in the center of the yoke and yoke will slide off the output shaft. its a good time to replace the output shaft seal as well.
Aug 07, 2011 | 1999 Ford Super Duty F 450
I need to know how to remove the bearing from the drum. I have split the outer drum but can't get the shaft out of the back of the outer drum? My washing machine is a Hotpoint WT 960
this just takes a bit of mucle and time.
remove rear pulley and then refit screw (without washer) into shaft. screw the whole way in. then using a lump hammer knock shaft out. may take a good bit of hammerin.
knock bearing out then and also unclog the weep hole in bearing housing.
grease the bearing housing and press in new bearing and seal.
if old shaft damaged ( which prob is if hard to knock out) you will need to replace it.
screws holding shaft to drum usually impossible to undo so drill them out using a 8mm bullet bit.
fit new shaft, put some bearing grease on the bearing seal and re-assemble the drum
Oct 19, 2010 | Hotpoint Washing Machines
I need to replace the bearings on lg wm2277
The metal covering piece is probably the outer seal for the front bearing--you remove both by driving the bearing out with a long metal rod (or a long punch) that reaches all the way through from the back (you have removed the inner drum and end shaft first). Tap fairly gently on the rod with a hammer and move the bearing end to another location after a few taps. The seal should pop out first, with the bearing next. Once out, look for a number on the bearing edge--it should match the replacement. Inspect the surface where the seal mates with the shaft--it should be pit and wear free. If it is not, a local machine shop should be able to repair that surface (and cheaper than a new inner drum assembly). It is essential that this surface be perfect as it keeps water out of the bearing behind it. The seal can be reused if it still fits fairly tightly on the shaft and that it was not damaged during the removal process. Check with a local bearing supply house to get a replacement bearing. The new bearing will have been greased at the factory, but you need to grease the shaft and inner seal lip with waterproof grease before installing the seal. Don't strike the inner part of the new bearing, only along the outer edge when tapping it back into the housing. Same with the seal. The far end bearing will likely be good and not need to be replaced--slowly turn the inside part and feel for any roughness which would indicate the need for replacement. If so, it gets tapped out from the front side in a similar manner as the front removal. Good luck!!
Dec 05, 2009 | LG WM-2277HW Front Load Washer
Underwire from a bra is stuck behind drum
You wouldn't believe how common that is. If you can see part of the underwire, unplug the machine first! Then, try to pull it out through the holes in the rear of the drum with needle nose pliers or vise grips. I can't stress enough the need to unplug the dryer first. On certain brands the heater is right behind the rear panel and depending on certain circumstances there could be 120-240 volts to the heater even though it is not hot and the underwire could either be shorted already or will short when you try to pull it out.
Dec 19, 2008 | Dryers
Replacing rear wheel bearings on 1999 hyundai sonata
  1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
  2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
  3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
with out sealed hub ,
  1. remove wheel
  2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
  3. remove nut then washer, wiggle brake drum and front bearing will come out.
  4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
  5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
with disk brakes
  1. remove wheel
  2. remove caliper/bracket
  3. remove rotor
  4. remove 4-bolts from behind,tap old hub out
  5. reverse procedure
Jul 19, 2008 | 1999 Hyundai Sonata
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Squeeking noise from drum when drying
Bit of a long shot, but I once had a machine with a crack at the root of one of the spokes on the big pulley wheel on the end of the drum - made a nasty noise once every turn as the belt tension came on and off that spoke. Good indicator of this would be if you can make the squeak happen when you turn the drum by hand, but this stops when you take the drive belt off. If the noise is still there with the belt off, try removing the hose that leads from the base of the drum to the pump and use the hole that leaves to try and find if anything (stray bra wire?) has got stuck between inner and fixed drums. Check for the same thing between the front edge of the drum and the back of the door seal. On some machines, you can also get a little access where the condenser plugs into the back of the drum. Finally, give the pulley wheel a good shoogle up/down, left/right and back & forth to check the bearings are OK (another long shot). A
Feb 20, 2007 | Hotpoint Aquarius WD640 Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
188 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
