Question about GoVideo VR3845 DVD Recorder/VCR
Govideo r6750 stuck tray
Tray is stuck and wont open any way to get the tray open not sure if a disc is in the unit or not. if you cant help me do you have an email address for govideo
My 10 year old nephew forgot to take a disc out and inserted another this stopped the tray from opening i had to undo the screws holding the cover and remove them .Good luck p.s. don't forget to unplug firse
Posted on May 21, 2008
Ok the question is how do reset my govideo because my kids changed the channel on my govideo and I cant watch movies bacause the image is messed up and can cant see the setup manuel . How do I reset my...
Hello
If you do not have a Progressive Scan television, the picture will be
distorted in Progressive Scan mode. To reset the unit to its normal
factory settings:
1* Eject any disc from the DVD disc tray.
2* Power the unit off and back on.
3* Press and hold the FF and REW keys on the front panel for
five seconds.
4* Power the unit off and back on to return to normal operation.
OK.
Jul 23, 2011 | GoVideo DV2130 DVD Player/VCR
Where do i find users guide for R6750 Dvd Vcr recorder by GO Video
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. Here is the manual / guide:
http://micromatikal.dlinkddns.com:8000/cust/R6750.pdf
Sep 06, 2010 | GoVideo Go Video DVD/VCR Combo
My Go.Video dvd player isn't working.
On some units there is a slot or hole in the bottom of the unit, under the dvd side, that lets you open the tray by turning or sliding a gear or lever. Do not turn the unit upside down or the disc will fall out of the tray and into the unit. If there is no hole, take the cover off and there may be a pulley with a belt or a gear that can be turned to release the disc. There are 3-4 screws that hold the dvd mechanism in place, if all else fails, remove them and lift the mechanism out, be careful not to damage any cables. Some times the tray face will not fit through the face plate so the face will have to come off with the dvd mechanism, the face usually just snaps on.
Sep 07, 2009 | GoVideo VR3845 DVD Recorder/VCR
Dvd will not play on my govideo dvr4250
Do you hear it spin up or not?
and if not the laser is in it's retracted
state when it should be up and reading
It probley out of timeing with
respect to the tray
you can fix this but you will
have to open it up to do it right.
Jul 01, 2009 | GoVideo Go Video DVD/VCR Combo
R6740 dvd recorder
I tapped on the top of the machine and it opened
Oct 26, 2008 | GoVideo R6750 DVD Recorder
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Region change to multi on govideo #DV1140
This might help some...no gurantees...... take care...
Kevin
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  1. Open the disc tray
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Jul 18, 2008 | GoVideo D645 DVD Player
Ps2 stuck on memory card screen
If its not an original disc, meaning if it was copied or burnt, then this will happen. However if it is in fact an original PS2 disc, then I'd suggest taking it out, cleaning and trying again.
Mar 21, 2008 | Sony PlayStation 2 (PS2) Console
DVD Recorder
sound like a micro glitch try unplugging the unit from the wall outlet and replug in after 30 sec.. should reset the system
Jan 17, 2008 | Televison & Video
GoVideo VR3845 DVD Recorder/VCR Logo
337 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
