Question about Consew 206RB
Thread won't stay in discs and under tension spring
I've checked the overall threading many times. It seems correct. But as I sew, the thread gets really slack and then comes out of the routing that's where the thread is routed under the discs that are part of the takeup spring. Once this happens, the thread gets on the back side of the discs, gets stuck, and then breaks. I can't figure out how to keep the thread routed under the takeup spring.
On the first set of spring loaded tensioner plates there is a small bar that comes out straight at you. Bring the thread over this bar before heading down to the next catch. Also make sure you do not have dirt in between the plates. The only other possibility is the tension release is easing the thread tension while sewing. (like your knee hits the foot lift or the whole foot lift is too tightly assembled
good luck
Posted on Jun 28, 2008
I notice the thread from the bobbin is loser than the one coming directly from the spool. Also, one side of the stitching seems normal and the other side seems like a long single stitch
That is tension. Sounds like you need to tighten the upper tension slightly to bring the bobbin thread up. The tension is correct when the upper and bobbin threads meet in the middle of the fabric. Also, tension will not always be constant. It may need to change as you change fabrics, thread, and as your machine ages, so it is best to get comfortable with adjusting the tension for each project.
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
How to Adjust the Tension on Sewing Machine
Jan 13, 2017 | Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
When i sew a test piece of fabric on my sewing machine to check the stitching, the top thread seems fine but the bottom thread is loose and adjusting the tension doesn't seem to help
there are two thread tensioners on a machine
the first one is on the front of the machine for the top thread
the second is the small screw that holds the small flat spring under which you pull the thread after you put the bobbin in the holder
as you put the bobbin in the holder you have to pull the thread around the side until it slips into a small slot then under a retainer spring
that spring is adjustable by that small screw
the amount of tension added or released by that screw is minute so as little as 1/8 turn has a big bearing on the amount of tension of the bobbin thread so turn it just a small bit at a time until the thread tension is correct
Oct 14, 2015 | Sewing Machines
Singer 8280 sewing machine tension won't increase
Make sure your needle and tread match your project. There simply isn't such a thing as a "universal needle." Also try lengthening your stitch. Heavier fabrics typically need a slightly longer stitch. Upon commencing to sew always grasp the 2 threads and slightly pull as you begin your seam.
I assume your garage sale find has a manual. Be sure your bobbin is unspooling in the correct direction. If it didn't come with a manual.. http://www.singerco.com/uploads/download/430_8280_es.pdf
Good luck.
Jul 04, 2012 | Singer 8280 Mechanical Sewing Machine
My Brother CE55000 sewing machine makes a grinding noise each time I sew on three layers of fabric. Thread bunches up under the fabric. What is wrong with this machine?
Does it sew okay on a single or double layer as this sounds like the threading up is not correct to me. The grinding may be that the bobbin case isn't in correctly.
However, best way to diagnose is to start fresh, take off the thread, remove the bobbin case, clean out the rotary hook (under the needle plate) clean the feed dogs and remove the needle. Clean the tension discs too (turn to zero and floss between the metal discs with selvage edge of a clean piece of cotton scrap fabric, until its clean, no gunk coming out). Turn tension dial back to 4 or 5, your normal setting.
Now wind a fresh bobbin making sure it winds nice and smoothly, keep tension onto the thread spool to achieve this and watch as the thread goes onto the bobbin, give it a nudge so it fills the bobbin smoothly across the whole core, top, middle and bottom.
Now put bobbin into bobbin case and ensure it goes into the tension spring correctly. I can't see an image of your machine to know if it is top loading or front loading bobbin, sorry. But refer to your manual to ensure you get the thread fully into the tension device. With a front loading bobbin, there is a removable bobbin case. Ensure that this is holding the thread with enough tension, if you suspend the bobbin and bobbin case and just hold the thread tail there should be enough tension on the thread that the case just hangs, but if you give it a litle jolt, it should release some thread. Adjust the tension spring with a little screw on it in 1/4 turn increments until you get it to this point.
Try this link for some images and trouble shooting help on bobbin case. http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If you can't get the tension right on the bobbin case at all, then take it to the Brother shop and buy a replacment one, sometimes the springs do fail on them.
Now put in a new needle and make sure you have used the right size needle for your fabric, ie medium weight woven you need a size 80 universal, but if it is a knit fabric like jersey you need a ballpoint 70 or "stretch 70" if its got a lot of lycra in it.
Now thread up the top thread and pay careful attention to getting the thread into all the thread eyes, particularly the take up lever and make sure it goes into the top tension discs fully (always thread with the pressure foot raised so the tension device is open). Lower the pressure foot and pull the thread just before the needle, it should feel very firm if the top tension is working right. If there is no resistance there, you've got a dodgy tension dial, take it for service/replacment.
Continue threading to the needle, bring bottom thread up to the top by turning the flywheel through one cycle towards you. Now hold both threads together at the back and test stitch a seam.
If you are still getting the noise from it and thread jamming up underside then the fault may be more timing related in which case you'll need to take it to a sewing machine technician too.
Sep 20, 2011 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I'm in trouble deep-I was trying to fix an old
Good day!
Good day!
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
Jams up when attempting to sew, making loud noise. Thread mass under fabric when able to cut loose from machine.
Thread jams underneath usually are caused by top thread tension issues. Things to check:
top tension discs are clean and no thread traces caught in there, tension is set to medium number usually 4 or 5 and that the top thread is running freely from the thread spool, correctly thread through the tension discs, and down to the needle. Lower the pressure foot and pull the thread from just above the needle; it should feel firm resistance if under tension correctly.
As you've had a good jam up, good idea to now remove the bobbin, needle plate and bobbin holder (refer to your manual if you have never done this before) and clean out the hook area well, look for any fine thread remants and brush out any lint etc. Oil the rotary hook area as per your manual. Now reassemble, and rethread everything again checking that the bobbin thread is clicked into the tension spring and that the top thread is through the tension discs correctly.
Also, pop in a new needle, flat shank to the back, then try again.
Good luck with your machine.
Mar 14, 2011 | Brother SE-270D Computerized Sewing...
Consew 206RB Logo
187 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
