Question about Maytag Neptune MDE5500AY Electric Dryer
I NEED FAULT CODES FOR DRYERS
I HAVE A MAYTAG COMMERCIAL DRYER WITH COIN OPER. KEY PAD. I AM LOOKING FOR THE FAULT CODES FOR MODEL NUMBER # MDG11PDAAW. CAN U HELP
  • TOOTONE May 28, 2008
    thank you for the help. the washers and dryers that i have are electric with turn key diag. modes. it seems that the codes that they are giving me are in the 100's and 200's. the codes that i am retreiving are read though the coin op pads not the washer and dryer them selves.
  • Anonymous Mar 19, 2014
    I need to know how to adjust the gas timer on the dryer? It is an old dryer LDO 26cS maytag
    President:
  • 1,314 Answers
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
Posted on May 21, 2008
I have a Maytag Commercial electric dryer in my home ,brand new sat for 2 yrs,got it to work 3 times,then quit.Computer panel was bad,replaced it,the model # is MDE22PRBYW0 not what's showing above
So then, you have purchased a computer panel that is designed for a "pay" machine., or perhaps for another model than you have.
(In that case, the "d5" would mean something else.)
Please look at "Sears Parts Direct" on your computer and see what they say as to your replacement panel part number.
What I do is then go to e-bay and search the part after I get the correct number.
I surely hope Sears will have the schematic for your machine.
God bless your efforts.
Feb 01, 2016 | Maytag MDE2400AYW Neptune Electric Dryer
On maytag commercial dryer model mde16pdayw, how do I set price?
That model ranges from 500 to a 1000 based on the condition and how new it is. More important is to search the local papers and internet ads to see if there are similar dryers for sale. If so compare those to yours as a guide. Another thought would be to visit apartment complexes and laundramats. Speak with a person in charge they may be looking to replace or add to the dryers on site
Feb 28, 2011 | Maytag MDE21PN Electric Commercial Dryer
Commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Jun 16, 2009 | Maytag MDE16PD Electric Dryer
Need mother board for maytag dryer model ldg23cd can not find one
I have about 20 of these boards in working condition. If you need one, let me know.
Coin Operated Double Stack Dryers - LDG23CD Dryer Board 3-6236 (or possibly 3-6443 or 9-12086)
Board - This part has been discontinued by the manufacturer and is no longer available.
Touch Pad AP4037678
Part Number: AP276590
Manufacturer's Number: 306236 (3-6236)
May 27, 2009 | Maytag MDE16CS Electric Dryer
Maytag commercial dryer rejects all quarter
Take out the coin slide and inspect for any worn parts. You can replace it for about $40
May 14, 2009 | Maytag MDG16PD Gas Commercial Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Find a manual
The coin operator timer consists of several small plastic gears. The teeth on the last plastic gear gets all chewed up so that the timer continues to run and unable to open the circuit which stops the dryer timer. Although the plastic gear probably costs pennies, your will need to order part number 33001275 torsion timer for about $75 - $110. Remove one screw & 3 clip-on wires - 15 min.
Mar 06, 2008 | Maytag MDG16CS Gas Commercial Dryer
I need the coin programming instructions
what sort of coin acceptor is it? single slot? multiple coin slide in? write me at my email: srf12980@localnet.com.
Sep 12, 2007 | Maytag MDE16CS Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
654 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
