Question about Kenmore Washing Machines
How to replace ccu on a kenmore he2 plus? - Kenmore Washing Machines
    Genius:
  • 1,028 Answers
F01 code??? remove 3 screws on rear of top panel ccu is on right side toward frontrelaes tb will allow ccu to slide badck remove wire connectors by pulling small tb away from plug andpulling connector straight upnew ccu should wire up just like old one but try to chane one connector at a time to avoid confusion
Posted on May 22, 2008
jsrock516
  • 5911 Answers
SOURCE: F05 Error Code on Kenmore Elite HE3T Washer Model 11044932200
First of all, make sure you unplug the washer before making any measures, and make sure you unplug any connectors from the CCU, so you aren't reading parallel paths. Isolate the components you wish to test from the CCU or you may get inaccurate readings.
The reading across the heating element terminal should read 15 ohms. Make sure you aren't grounding your probe against the case, or you will get improper readings.
The NTC will read approximately what you have at room temperature. Was the connector plugged in before you began troubleshooting? A common problem is the connector falling off and generating the error code.
As far as the connector plug on the CCU is concerned, plug layouts can differ between models. Make sure you have the correct connector plug to the NTC. You may have to hand over hand it to find it. Unplug the connector at the CCU and leave it plugged in to the NTC. Perform a resistance check across the PLUG terminals. You should get the same readings as you mentioned before if the plug and wires are good. This not checks the resistance of the NTC, but also proves continuity of the wires.
Doublecheck your readings and let me know what you have. I would like to rule out a CCU problem. It is not common for this error code. I hope this helps you.
Posted on Sep 05, 2008
SOURCE: Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Hope this helps everyone else as it did me, thanks
Posted on Dec 02, 2008
localwonder
  • 6784 Answers
SOURCE: kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
Posted on Sep 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: Kenmore HE2 Plus Washer CCU
Welcome to Fixya.
The central control unit, aka "CCU" is the control located to the right of the main console when you remove the top. ( approaching from the front )
The part number you want is W10205848 as listed by "searspartsdirect.com". ( Also available at many on-line vendors such as "repairclinic.com" which use there own stock number 1547531 )
I do see a fair bit of these since I am presently a Sears service technician ( after being independent for over 15 yrs. it`s an adjustment...but that`s another story :P ).
It should look like the image I`ve attached to help you identify it more easily...
Hope this answers your question. Thank you for choosing "FixYa" for your repair needs.
Please take a moment to rate the info I provided for you here and a testimony if you feel it warranted.
Thanks again and good luck.
macmarkus :)
Posted on Jul 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error F28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
F33 flashing during cycle I have a kenmore HE2
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Feb 13, 2011 | Kenmore HE2 Plus Front Load Washer
F 01 code door don't lock
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Dec 29, 2010 | Kenmore HE2 Plus Front Load Washer
I have a F01 code
Apr 13, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus washing
Sep 18, 2009 | Washing Machines
Need ccu board replacement
REPAIR CLINIC.COM ITEM#1164545 $179.70
Apr 06, 2009 | Kenmore HE2 Plus Front Load Washer
Error F28
Apr 03, 2009 | Kenmore HE2 Plus Front Load Washer
I have an error code of F-01 on my Kenmore HE2 Plus washing machine. What does this mean and how do I fix it.
Your washer needs to be serviced by a professional. That error code means there is a communication error between the Control Unit and the EEPROM; the CCU needs to be replaced. Check to see if your product is still under warranty.
Refer to page 2 of this service manual:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208540259.pdf
Mar 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
632 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
