Question about Microsoft Office Professional 2007 Full Version for PC
Setup cannot find Enterprise.WW\EnterWW.cab. Browse to a valid installation source and then click OK. I am installing MS Office 07 and midway through the install this is coming up. Any answers to this problem?
  • 1 more comment
  • j_r_c_2462 Sep 24, 2010
    I'm installing MS Office Enterprise 07 and midway through the install this pops up- Setup cannot find Enterprise.WW\EnterWW.cab. Browse to a valid installation source and then click OK. I have had this version on this computer before but had to wipe the HD due to a virus.
    I thought that fixed the problem as a couple install bars popped up and then the message popped up again and the two bars disappeared.
  • norvellaj
    norvellaj Jan 29, 2014
    clean the disk and retry
  • 734 Answers
Hi There,
When it asks for the "valid installation source", direct it to the installation CD drive where the MS Cd is. There's a good chance it will heal itself that way and move right on ahead.
Regards,
Marcus
Posted on Sep 24, 2010
  • 3 more comments
  • DaveQuintero May 05, 2011
    Wow, perfect solution who would think???
    Thanks for posting
  • ben ghorbal sliman Feb 15, 2013
    hi ! many thanks.it was very helpful though with a lot of patience
  • Willanda
    Willanda Dec 06, 2013
    Worked on this same issue for 2 1/2 days after my computer crashed. I did have software completely installed before the crash. Yelp after reading all of the online help nothing worked. I got the same validation messege and as above directed it back to the cd. That did not work, so I directed it back to the Office 2007 folder and behold it worked!!!
  • Saba Naeem
    Saba Naeem Apr 06, 2014
    thanks willanda that really helped
  • Hafeez ullah
    Hafeez ullah Apr 03, 2019
    saba naeem can you explain to me this installation of ms 2007 how it installed i don,t understand english more as well as you
    New Friend:
Problem:Office Installation Problem : Setup Cannot Find Enterprise or Some Other Files
Solved Solved Solved
Goto Control Panel -> Add or Remove Programs Then you will find corrupted version of Office try to remove ...it says it cannot remove as it is corrupted so then go to C:Program Files , Open Microsoft Office Try to Delete Files ....Grroveutil will not delete ...Files which cannot be deleted cut and paste in D Drive...Rename the Microsoft Office Folder in Program files deleting or cutting all files...then try install again ....after complete install reboot ....Hurray Office will Work
Posted on Mar 12, 2011
    New Friend:
I had the same problem and none of the online solutions helped. I worked on it for 3 days. Even thoughh I was the "Adminstrator" and logged in as "administrator, it turned out not all folders under Windows folder had permissions set for access. So I went back to the 'C' drive Windows folder and I went through and changed all permission on each folder and used subfolder option to make sure all subfolder got changed to FULL Control. After doing this the installation went through 100%
Posted on Dec 01, 2010
  • adriaDM Jun 23, 2011
    did you already installed the MS to ur pc coz i have a same problem too... please help me!
  • amarshell1
    amarshell1 Sep 05, 2012
    please remove the Microsoft Office where you installed it i.e.,( C:/ProgramFiles) then there is a MIcrosoft Office Folder... you delete that once... then it works 100% :)
    New Friend:
Please remove the Microsoft Office where you installed it i.e.,( C:/ProgramFiles) then there is a MIcrosoft Office Folder... you delete that once... then it works 100% :)
Posted on Sep 05, 2012
    New Friend:
Non of the above work in my pc
Posted on Jul 05, 2013
    Sergeant:
  • Microsoft Expert
  • 141 Answers
For Microsoft Office technial errors, the easiest way is to reach Microsoft customer service. They provide an instant solution and help for email setup and password related issues.
Services offered-
Microsoft account setup
Microsoft password reset
Outlook technical support
account live password reset
Microsoft sign in errors
Install MS office
Setup ms office
MS Office 365 setup
Dial directly 1888-315-9712
or visit toll-free Microsoft Office Technical Support Number from the below link-
http://bit.ly/2D04f8q
Posted on Feb 02, 2019
    Master:
  • Microsoft Master
  • 459 Answers
1) In the Control Panel, select the Add or Remove programs. You will notice an outraged version of your office.
2) Remove the corrupted file. In case if you are not able to remove the file, go to the C drive and select the Program files.
3) Move the files to D drive when you are not able to delete it. Remove the files and try to install the software again.
4) The Microsoft Office will now work.
Posted on Dec 29, 2018
    New Friend:
Posted on Nov 27, 2012
SOURCE:
Setup cannot find Enterprise.WW\EnterWW.cab. Browse to a valid installation source, and then click OK. "
try using another installer of MS Office Enterprise 2007. You could download it on this link:
tinyurl.com/fixyaenterprise
Hope this would help!
May 25, 2011 | Microsoft Office Professional 2007 Full...
I am trying to download Microsofe Office 2007 using a software and during teh installation progess I am prompted with a message "setup cannot fine enterprise.ww/enterww.cab broswe to a valid installation...
I'm assuming that you bought it legally. The source of the installer is corrupted. Either get it directly from another source
http://www.brothersoft.com/microsoft-office-60484.html
or just get rid of it and install and use Open Office
http://www.openoffice.org/
Jul 08, 2010 | Microsoft Office Professional 2007 Full...
Crc failed in Enterprise.ww\enterww.cab
Based on my experience there are many reasons that this issue may occur. I
suggest you try the following suggestions:
* Suggestion 1: Clear Temp folders
1. Click Start>Programs>Accessories>Disk Cleanup
2. Clear your Temporary Internet files and temp files.
3. Restart the PC.
4. Copy your Office 2007 files and folders to a local folder.
5. Double click on the Setup.exe to start the install process.
* Suggestion 2: Check the Environment Variables
I remember I have resolved some similar issues that the users report Office
2007 has failed to install. I have figured out this is caused by the wrong
configuration of the user variables. To check it, please follow the steps
below:
1. Right click on Computer, and choose Properties
2. In the Tasks list that appears on the left, click Advanced system
settings.
3. Click Advanced tab, click Environment Variables.
4. Under User variables for user name, check if TEMP is configured as the
following value: "%USERPROFILE%\AppData\Local\Temp"
* Suggestion 3: Install under Vista safe mode
Please try to install Office 2007 under Vista safe mode:
1. Restart Windows.
2. At the boot sequence, long press F8 key to invoke startup menu.
3. Choose Safe Mode with network connection on the menu and press Enter.
4. After Windows starts in this mode, install Office 2007 again and see the
result.
Feb 04, 2009 | Microsoft Office Professional 2007 Full...
Ent 2007
You search for it on the CD if that is where you are installing from.w You would search for *.cab..
Jun 27, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
46,189 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
