Question about Brother IntelliFax-4100e Fax
Outgoing faxes I have a 4100 Intellifax, and when we send outgoing faxes, the recipient gets a very dark, black blurry page. We receive faxes with no problem. Help!
  • nancyhylind Apr 29, 2009
    A fax sent out is entirely black, an incoming fax is perfect and if
    copying, a 1/2 inch black line runs down the entire page in the
    left/center area.
    Genius:
  • 2,120 Answers
Not good! It sounds like you have a bad scanner assembly. Make a copy of something and you probably will see the same result.
Posted on Sep 26, 2008
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 laser fax
Clean the roller with alcohol and then try. It will work fine.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Black page when copying and sending faxes.
You most likely have a bad SCANNER BLOCK. Not good!
Dec 23, 2008 | Brother IntelliFAX 4100 Laser Fax
Black line on all faxes I send to recipients
open the document feeder and look for wite-out on the small scanner glass.
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Can't receive outgoing faxes, but CAN receive in-house faxes
MAKE SURE YOUR PHONE LINE IS PLUGED INTO THE JACK ON THE FAX THAT IS MARKED LINE ALSO CHECK THAT THE MODE KEY IS SET TO FAX
Oct 23, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-4100e Fax Logo
610 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
