Question about Toshiba Satellite Computers & Internet
Toshiba Satellite T135-S1330 shuts down by itself. Tried rebotting in safe mode, shut off all startup programs, restored to previous point, was running a virus check when it shut off again. Has happened about 5 times now. Most recent fix attempt was booting, F2, resetting bios configuration.
  • Brett Duxbury
    Brett Duxbury Feb 04, 2018
    Hi Andrew Paez, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    has it got power when you plug in ac - dc power adapter and plug in the DC plug to the laptop does it look like the battery is charging maybe measure the voltage out of the power pack ?
    Habit-Forming:
    New Friend:
  • 112 Answers
Do you still hear (feel) that the cooling fans are working ?
Maybe the fans are clogged by dust and the processors are overheating!
Try a vacuum fast clean on the exhaust hot air holes, it can help!
Posted on Feb 04, 2018
cpenzes
  • 1102 Answers
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Posted on Feb 09, 2009
  • 51 Answers
SOURCE: Toshiba Satellite Laptop M35X-S167 - Windows Won't Start
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Posted on Aug 22, 2009
info95358
  • 8 Answers
SOURCE: toshiba satellite laptop will not boot up. The
If you want to fix blue screen problems yourself I recommend using a program from spotmau. They have software you can boot from which will fix most startup problems. I also recommend booting in safe mode with networking first and scanning your PC with Avira antivirus. Or you could go the easy way and hire someone locally which should fix your problem for no more than $50. Good site to check out www.oncallers.com
Posted on Oct 05, 2009
  • 18 Answers
SOURCE: My Toshiba A200 laptop keeps freezing up about 1-5
I think you antiwirus has damaged the system files and you should just re instal the opperating system
Posted on Nov 18, 2009
  • 20 Answers
SOURCE: Toshiba Satellite A210 will not boot
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena8
Posted on Jan 03, 2010
What is causing my toshiba satellite p755-s5385 to shut down?
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 15, 2013 | Toshiba Satellite P755-S5385 Laptop...
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Tried the solution...Satellite A85 desktop with no iocons or task
freetek suggested booting to Safe Mode and using Restore function; did a restore to earlier than when problem started, and it worked! However, the nesxt day when I started the laptop again, it returned to the Desktop with no icons or taskbar, causing me to have to remove battery to shut down system. Tried a second Restore to a same checkpoint...would not allow me to re-use that previously used checkpoint, so went one week further back. Did not work and all laptop will do is boot top Desktop with no icons or taskbar and I have to remove the battery to turn it off.
Oct 01, 2009 | Toshiba Satellite A85-S107 Notebook
My HP dv5-1125nr has had a fatal error and has completely shut down. How do i do a recovery?
Turn your computer on. Keep pressing the F8 key until the Windows "startup" menu appears. Choose "Safe Mode". Click "Start". Click "All Programs". Click "Accessories". Click "System Tools". Click "System Restore". Select the most-recent "Restore Point" before the problem, and let Windows restore itself to that date/time.
Jun 08, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
Toshiba Satellite A105 problems
Sounds like a program is not loading properly. You should try to load in Safe Mode, And see if it starts properly. If it does you then can do the diagnostics to find which program is trying to load and shuts machine down. You may also try starting in step by step and catch it right away. Depending on your version of Windows you are running you may be able to restore to a previous time when your machine worked right. Good Luck and have a good day.
Mar 08, 2009 | Toshiba Satellite A105 Notebook
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
I'm getting a Black Page
try to boot in safe mode when prompted on startup when u forcibly shut down ur operating sys it will present u with a screen to select safe mode on startup just go thru safe mode and try using system restore in the Start> All programs> accessories>system tools>system restore try to restore on the earlier date when ur sys was ok see if it helps pls vote if u think i was helpful
Jan 29, 2009 | Toshiba Satellite P105-S6227 Notebook
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Computers & Internet
Unistalling macfee Toshiba Satellite P205-S6287
Try starting up in safe mode by pressing F8 a few times during boot to get the bootup menu. Select safe mode by itself. If you have system restore on then you can try to revert back to right before you installed mcafee. Your machine probably created a restore point right before the software installed. This would be the easiest way to get around this issue. Another way would be to boot into safe mode then go to start -> run and type msconfig then press enter. The System Configuration Utility should come up. Go to the startup tab and uncheck all mcafee related items. Click OK then reboot. McAfee won't start on boot and crash your machine and you can then uninstall it. Be careful with this step though as you could make things worse by unchecking the wrong startup items. Its best to try and revert to a restore point first.
Aug 20, 2007 | Mcafee WebShield 3100 (EPL310ANA300)...
Computers & Internet Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
