AC adaptors replacements
I have a broken AC adaptor, which is 18v, .7A, for Acoustic Research AW-877 speakers. If I replace it with an 18v, 1A what problems may I face?
    Problem Solver:
  • 16 Answers
You will not have any Problem What so ever.
18V is operating Voltage,
0.7A is Max of Current it (Power Adapter) is providing.
The Load (AR) is operating (Uses Current) between 0~0.7A (Even Less)
Therefore 1A Adapter is actually safer to use.
Think as, your electric company supplies 100A Service,
and you have only AC is running at 10A.
Posted on May 22, 2008
My remote speaker system works with the batteries but not with the AC adaptor plugged in to the speaker.
I would suggest to check AC outlet first where adaptor is pluged in,if Ok measure output voltage from adaptor to see if there is any (using any voltage multimeter with AC/DC)
Check label on adaptor shold be writen AC or DC output ,and value 3V,6,9,12,24,48 etc...
If adaptor is ok then problem is power jack mounted in to the speaker (cold solder joints' or damage)
Aug 23, 2011 | Audio Players & Recorders
The power supplies / ac adapters for my AW-871 speakers were both lost in a recent move. The speakers show input of 15v center + but no power spec. Do you have a suggestion for replacements? Thanks for...
Higher voltage then required is not so recommended, internal circuit may over voltage driven. some power amp max limit may fall within 18V only. See this link If your speaker power less then 30w you can choose 15V 2A will do or else select higher spec.
Jul 23, 2011 | Acoustic Research 900MHz Wireless Stereo...
My Acoustic Research HTB-80 Speaker Bar stopped working after a storm. No lights/power. Is there any fuses in the unit that I should check?
if your unit come with external Adaptor power up type. then mostly is the adaptor already blown, replace the adaptor will do.
Jun 24, 2011 | Acoustic Research HTB-80 Speaker
Where can I get replacement earpads for the AW-721?
http://www.gifts.com/ssp?slkw=replacement%20earpads&testcell=B&adid=1288827692-1992034d-0-p-gf_mps&ref=replacement%20earpads%20for%20aw721&creativeid={creative}&site={placement}
Jan 13, 2011 | Acoustic Research AW-721 Consumer...
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
Need a replacement AC Adapter for Advent AW-820
Any AC to Dc adaptor will work. Just make sure is the same spec as the one you have.
Try Mcmaster Carr
Feb 18, 2009 | Recoton Advent Advent AW-820 Main / Stereo...
Wireless speaker won't come on after plugging in now....
Try the adaptor that you know works in the speaker that doesn't. That will eliminate if its the adaptor or the speaker. You will need a multimeter to check if its the on /off switch or not. A quick alternative is to "bridge" out the on / off switch wiring. (Use a piece of wire to join the wires going through the switch together.)
Sep 04, 2017 | Acoustic Research 900MHz Wireless Stereo...
AC ADAPTER
The AC adaptor is a 9v 2.2a AC adaptor. You can also use a 12v 2.0a AC adaptor.
These are available at just about any electronics retailer.
Nov 17, 2007 | Insignia IS-PDVD10 Portable DVD Player
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
155 people viewed this question
 Grubhead
Grubhead
