Question about Weaver Riflescopes T-Series Adjustable Objective Silver Matte 36x40
Weaver T-36 scope fails to hold zero
I have a Weaver T-36 that is several years old. It recently started "losing" zero and has to be adjusted to maintain zero. I've tried turning vert and horiz all the way down and returning to preset point. It lasts a couple of shots then goes high left perpaps 1" high and 3/4" left. No one seems to have solution short of swapping.
Thanks,
Mike
"Iron Sights" in Tulsa, Ok does service work and has parts for the original El Paso type Weaver scopes.
They have did an excellent job on my old Weavers.
They are slow turnaround, but excellent work.
Posted on Feb 05, 2011
Scope will not zero in. Had the scope for three years Had no problem till recently .
Scopes have a spring on one side of the optics tube and a screw on the other side. This is for up and down and side to side adjustments. The issue appears to be that the springs have lost their point of contact or tension.
Nov 22, 2017 | Bushnell Sportsman Rifle Scope 3-9X 40...
Directions for mounting weaver 1inch see thur scope mounts
there the same as any other mounts,,, screw then down on a wever mount and plonk your scope into them,,,then re-zero the scope
Nov 27, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
I have the 6x18x65LU atn rifle scope. I had the scope mounted to my 30-06 on two 1" weaver rails. the scope keeps sliding forward though the adjustable scope rings. I've been recentering the scope and...
be cearfull you dont crush the scope tube,,but try rapping a little strip of sticky rubber or plastic tape round the scope tube then nipping the scope ring caps down onto this,,,but i think your scope rings are worn out or the wrong size,,ie 30mm not 25mm
i have air rifle scope's on my 7.62/308 and on my 303 none of them move about at all and they have stayed on zero for years now!
Aug 25, 2010 | ATN 6-18X65LU Daytime Rifle Scope
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
Apr 17, 2010 | Cabela's Optics
How to readjust a weaver mount?
Make sure the nuts are on the same side of the rifle (both on the right OR left). The clamping mechanism can vary the centering of the scope if they are on opposite sides of the mount.
The other problem may be poorly drilled mounting holes on the receiver or scope mount, check these for alignment with your bore or barrel.
Mar 15, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
I have a weaver k-8 scope with adj. rings on front bezel ??????
the front ring is for adjusting point of impact at a given range,,,its called a "parallax ajustment" it corrects for the scopes inaccuracies over its full range say from 10 yds to 100 yds there a bit of a pain on a hunting rifle as you need to focus them every time and that slows down your shooting, when only a snap shot will get the kill you cant wate to mess about focusing the darm scope so i never use them on my rifles,,unless im target shooing,, or im snipping when i have time to take my shot,,,
(a head shot only!) only a parallax scope is spot on aim from 10yds to infinity
Nov 18, 2009 | Weaver Optics
On scope adjustment my older weaver 3x9 micro trac dosent have clicks just marks on the dial how much change in 1 mark movementscope is about 20 years old
Most of the older type scopes were rated at 4 clicks per inch at 100 meters.But to be sure you will have to test it. I generally do that at a 50 meter range and then it is 4 clicks per half inch.
Oct 11, 2009 | Weaver Rifle Scopes Grand Slam Silver...
Overtighten causes hazing,and adjusment problem
As a general rule of thumb, If you have normal Weaver-type aluminum rings, you tighten to 10 to 15 inch-pounds. If you have normal Weaver-type steel scope rings, you tighten to 15 to 20 inch-pounds. If it's something exotic and/or expensive, you're pretty much stuck contacting the manufacturer. Leupold Mark 4's require 65 in-lb, for instance.
Wiha makes two adjustable torque screwdrivers (one for lower torque, and one for up to 60 in-lb that are perfect for most any scope ring applications.
May 04, 2009 | Leupold ® Rifleman® 3-9x50 mm Scope
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
Optics Logo
555 people viewed this question
Top Weaver Optics Experts
Mark Campeau
Level 1 Expert
freebyrd04
Level 1 Expert
colinat108
Are you a Weaver Optic Expert? Answer questions, earn points and help others
