Question about Lowrance GPS
I bought a I-WAY 250c in April 2007 and have been very happy with it but now when I turn it on, it tells me that it requires updating because it's over one year old. I connected it to my computer using the USB cable provided but can't understand how to download the updates into my unit. Can you help?
    President:
  • 2,712 Answers
Hello johnnydionne,
The procedure for updating will probably be to run the installation program with a 256 MB / 512 MB SD card in the slot and the iWay connected via USB. Download the files manually and copy them to the SD card itself. I assume you'd disconnect the iWay from the PC and power-cycle it to begin the update (I just used my external SD card reader to load the card and booted the iWay with it in the slot).
You CAN update with the USB cable to a 256 MB or larger SD/MMC card. The reason you can't do it to the built-in disk partition is it's small size. There must be enough free storage available for the whole 200+ MB to fit. This is due to the operating system's "hiding" of the larger partition of the disk. If the disk were all visible, there would be nothing to prevent you from redistributing licensed, copyrighted map data.
You insert a 256 MB or larger card in the SD/MMC slot with the iWay connected and the installation program will happily write to it. Remove the iWay from the USB port and power it off, then on to begin the update.
You can find the update and instruction manuals here:
http://www.lowrance.com/Products/Automotive/iWAY-250C/Downloads/
If you need to speak with a Customer Service agent, please call the toll-free Customer Service line at 1-800-324-1356. Technicians and representatives are available to help you Monday through Friday from 8 a.m. to 5 p.m. CST, except holidays.
Hope that helps! Should you have any further questions, please post them here.
If you are satisfied with my solution or have no further queries, please take a moment to "Accept" this solution.
Thank you for using Fixya!
Cheers!
IrishDruid
Posted on May 21, 2008
    Genius:
  • 3,422 Answers
The latest update version is 1.3
So the first thing is to see if your already using this version.
  1. Select the MENU icon on the display of your iWAY™ 250C.
  2. Select "Options".
  3. Select the third tab, "Page 3".
  4. Select "Device Information".
  5. The software version for your unit is located under the line that says "iWAY 250C".
  6. If your version is the same version listed above, there is no need to download the software.
And if your not using this version then you'll have to update it.All you have to do is CLICK HERE and everything is explained step by step clearly.This will fix your problem.
Goodluck,
Please don't forget to rate or accept the solution
  • 3,037 Answers
Here is a link with the instructions for downloading the updates for your specific device
http://www.lowrance.com/en/Products/Automotive/iWAY-250C/Downloads/iWAY-250C-Software-Update/
Please let me know if you run into any trouble or need any further help with this as I would be glad to do what I can
good luck
  • 13,433 Answers
Did the gps come with a software?
with the software you should be able to download and install updates. I'l have to check.
  • 1 more comment
  • Ekse May 21, 2008
  • Ekse May 21, 2008
    Instructions, as on the webpage
    Installation Instructions
    1. Plug an SD/MMC memory card with at least 20MB of free space into
      your iWAY™ 250C, power on the unit, and wait for the unit to complete
      startup.
    2. Set the iWAY™ 250C power option to “Power Off”. To do this, press
      the menu button, select “Options” and then select “Setup” - Then the
      “Power Off” option is accessible.
    3. Turn the iWAY™ 250C off, and then turn it back on.
    4. Wait for the iWAY™ 250C to complete its startup, and then connect it to your PC with a USB cable.
    5. Click on the "Install This Update From the Web" link below.
    6. Wait for the Java web installer to download and run. Follow the
      Lowrance update installation instructions. During the installation
      process, you will be asked to select the drive associated with the
      iWAY™ 250C. If you can not locate the drive associated with the iWAY™
      250C, please read this FAQ regarding Drive Conflicts. When the installer finishes you will be prompted to click Finish to exit.
    7. Stop/Eject the USB Mass Storage Device associated with the iWAY™
      250C. For Windows, you can do this by opening the "Unplug or Eject
      Hardware" icon. This icon is located on the Windows toolbar near the
      clock (typically the very lower right-hand corner of your screen), and
      appears as a green arrow over the top of a small gray box. Once this is
      opened, highlight the USB Mass Storage Device and click the "Stop"
      button. Then in the new window, highlight the "Lowrance iWay 250C USB
      Device" and click the "OK" button. For Mac and Linux, simply
      dismount/eject the drive associated with the iWAY™ 250C.
    8. Disconnect the USB cable from the computer and the iWAY™ 250C.
    9. Turn your iWAY™ 250C unit off. Make sure to turn the unit
      completely off, and not just standby mode. To make sure the unit powers
      completely off, enter the Menu area, select "Options", select "Page 2",
      and then click on "Interface Setup". Choose "Power Off" as the "Power
      Key" option.
    10. Turn your iWAY™ 250C unit back on. The software update will
      automatically install. The installation process could take a long time
      to finish - please do not press buttons or turn off the iWAY™ 250C
      during the installation process.
    11. After the iWAY 250C update has finished, reconnect it to your computer via USB, and delete the update files from the iWAY 250C.
  • Ekse May 21, 2008
    Please use the webpage I provided to perform the update.
POI DATA DOWNLOADING
Important note about maps: Due to our high volume of sales, every Garmin portable GPS navigator sold by Amazon.com will come with the most recent map version. The current map provides data through April 1, 2007. If you purchased a Garmin GPS before April 1, 2007, you can purchase a map update on SD card. We will notify customers who purchase from Amazon.com via e-mail whenever new map updates become available.
Feb 02, 2008 | Garmin StreetPilot 2610 GPS Receiver
Cant get the usb cable or port to recognize the gps
This is the info from the Lowrance website
Begin with the iWAY 250C turned off, not just on stand-by. Stand-by is the default setting for the unit when powering down. Change the settings in the interface menu to power off instead of defaulting to stand-by when the power button is pressed. Connect the iWAY 250C to an available PC port. With the PC turned on and operating, turn the iWAY 250C on. The PC should make a sound recognizing a USB connection. If there is no audible sound, try another USB port on your PC. If there is a tone of recognition and the iWAY 250C is not displayed as a separate drive in My Computer, there may be a drive conflict. Change the drive letter of the iWAY 250C. Click here if you have a drive conflict with Windows 95, 98, or ME.
Apr 25, 2010 | Lowrance iWAY 250C GPS Receiver
Need a fully working Lowrance 250C GPS SD card or a copy of the same.
I have had a similar problem and founf this site where you can get a new card that will work for your GPS. Info, pasted below:
The Nextar GPS-MAP09SDC SD card with updated navigational maps and information has a MSRP of $69.99. Please visitwww.nextar.com to purchase the map upgrades and for more information on upgrading your maps.
Apr 18, 2010 | Lowrance iWAY 250C GPS Receiver
My laptop keeps asking me of product key,i bought it since april this year.Hp windoms vista
product key is the serial # that came with vista when you bought and installed it, it must be applied to register and get updates
Jul 25, 2009 | Microsoft Office Professional 2007 Full...
Data card lost all it data
I don't know how it would have "lost" all it's data. More likely is all of it's data was "erased" or "deleted".
Take the card out and put it into your computer or someone else's Iway and see if the file folder is still on there. It probably is. You might just need to reset your Iway. You also might try downloading the newest software update (ver 1.3) from the Lowrance website. http://www.lowrance.com/en/Products/Automotive/iWAY-250C/Downloads/iWAY-250C-Software-Update/
This is not the maps, it's just the software for the unit itself.
If the map file actually isn't on the card anymore, then ask yourself:
Did you make a data card backup to your computer like the user manual suggests?
If yes, put the backup file onto a 2GB SD card and stick it back into your Iway.
If no, then you're out about $90 to buy a new set of maps. They come from Navtec, you can't buy them from Lowrance because Lowrance doesn't produce them.
Good luck
Dec 30, 2008 | Lowrance iWAY 250C GPS Receiver
Lowrance 250c map update
http://www.lei-extras.com/store/search.asp?SearchType=Unit&Unit=iWAY+250C
You need to buy the Navteq map update, but you can call them and send in your memory card they will update it for a reduced cost, since 75 plus 12 shipping is too much just for maps, you can buy a whole new one.
Aug 14, 2008 | Lowrance iWAY 250C GPS Receiver
Please tell give me detailed instrucions on how to upgrade my Tomtom Navigation system. I bought it on the 7yh April 2007.
Ok, here we go:
1: Do a completly backup via win explorer or similar.
Copy entire content of unit to a folder on your computer.
Remember to set win explorer to show system/hidden files.
2: Make an account here for free:
http://www.tomtom.com/myTomTom/myProfile/index.php
3: Download and install TomTom Home:
http://www.tomtom.com/support/support.php?ID=3&Language=4
4: Connect unit to PC, TT Home starts up. If TT Home doesn't start, start it up manually.
5: When unit tells you to, tap Connect to computer
6: Log on with info from account creation, step 2.
7: Push Update my device from within TT Home.
8: DO NOT disconnect the unit while updating.
When updating is finished, disconnect unit.
The unit will then reboot, and you are done...
Tips:
You can get one free map update if a new map is avaible within 30 days from when you first started to use the unit. This is done through TT Home...
Good luck.
More questions, don't hesitate to post them here.
(Please remember to rate this solution....)
Apr 16, 2008 | GPS
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
GPS Logo
131 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
