Question about Freezers
Fridgidaire chest freezer problem
My chest freezer just stopped working the other day. I think I can hear the condenser trying to kick on, but it just clicks and thens 2 seconds later clicks again, and nothing happens. I unplugged the capacitor from the side of the condenser and and tested it. It reads 14.9uf and it states that it is a 15uf, so it's good. I would think it's a relay, is this your thoughts also? Any help would be great.
    Genius:
  • 1,122 Answers
Go to your local appliance store and buy a 3 in 1 starter kit,install, directions are with kit,this is your last hope as the compressor is getting weak,hope this help-mike
Posted on Jun 02, 2008
Switch comes on and goes off but compresser wont kick in
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 24, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
My 10 cf Magic Chef Chest Freezer Model# MCCF10WMD just stopped getting cold. The compressor kicks in for about 5 sec. every halfhour or so. Is it the compressor or the relay? I thought it might be the...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 30, 2010 | Midea Chest Freezer MCCF10WMD
I have had my freezer for a yr and one day it stopped running
heatman101
Jul 20, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped...
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Jul 25, 2009 | Haier 3.6 cu. ft. / 102 liter Chest...
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Meat is frozen but ice cream is soft
heatman101
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Bar Chest Freezer Large
I would think that the reason the red power wire melted, was because of high amperage, not getting wet. After you replaced it the condenser fan came on, but did the compressor? It may have went out before and that's what caused the bad wire. If you have a volt/ohm meter I can help you check it out.
Jan 29, 2008 | Summit Commercial 7.50 cu. ft. / 212 liter...
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
151 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
