I have model no. th-42px80u a dvd was connected by the crew who assembled the tv and it works ok . i am unable to connect a VCR so i can get a picture. have followed connections as shown in the operating 9nstructions.
    Novelist:
    Scholar:
  • 100 Answers
Salutations elderhostel,
Looking at your unit, it would appear that you would need to connect your VCR to the line listed Video In 1. Standard setup would allow for the red and white audio connections, and the yellow video connection (or S-video if your VCR provides this output). You then should be able to select Video 1 with your TV/Video button on your remote.
I hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 21, 2008
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
LCD TV connection to DVD-VCR
OK here is a possible solution: 1) The best solution: Connect the antenna to your DVD-VCR through the RF Input and the the RF Out to your TV This take care of the VCR part. Then you get an RCA three way cable (Video-yellow marked, Right Audio-Red marked, Left Audio-white marked)connect the yellow marked RCA cord to the Video out of your DVD player then connect the other end to your video in of your TV. Ater that connect the red marked audio cable to the R Audio out of your DVD player to the R Audio in of your TV do the same for the white marked Audio cable. You will now be able to switch from VCR-RF to DVD-RCA.
Sep 11, 2007 | Televison & Video
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Nov 01, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
TH-42PZ77U Blinks 10 times (worked fine for 1 year)
The P, PA, DH, H or DT board may be defective. Email for some help...
Best regards
gysgt2u1@yahoo
Dec 26, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
What wires are needed?
You will, at least, need what is called "component cables", usually remembered as "the wire with those three colors; red, white, and yellow". Connect those little plugs to their respective jacks on the back of your player and TV; color to same color, "out" on the player, and "in" on the TV.
Nov 12, 2008 | Samsung DVD-V2000 DVD Player/VCR
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
